This thread will document any work done to put the entire driveline of Cruzen2.0 in the back.
The goal is to have a mid-engined rwd cruze that still looks stock.
Progress will not begin immediately but I will update as soon as some is made.
This thread will only contain bits regarding the conversion, all other mods will still be posted under Part 2.
Why remove the drivetrain from the front?
Just stick another one in the back.
Car and Driver did that with a CRX in the 1980s, and two Accord drivetrains (automatics).
Will enjoy watching your project.
When the LE2 came out, I thought it would be fun to put it (along with the subframe and suspension) into the back of a Fiero. Weight loss and hp increase would wake up that old plastic Pontiac.
The RWD conversion was always in the cards for 2.0
Actually, I haven't really made up my mind if it will be 2.0 or another Cruze that will get the RWD conversion but for right now I've been thinking about it enough that I figured I might as well say something about my plans. The original idea involved a Pontiac Grand Am and a modified frankenstein's monster of a turbocharged ecotec and it has evolved from there. If I use Cruzen2.0 it will be the LHU out back, otherwise it will be a cobbled together monster of a 2.3L turbo ecotec with aftermarket ecu.
While I'm at it, I might as well confess to plans for a Cruzen3.0 with a Cadillac 3.0TT (and AWD) from a CT6. That would definitely require an aftermarket ecu, not just a body swap like 2.0
@Blasirl I'm stupid enough to try it but realize suffering will be involved and I'll probably do it anyways. Regardless, I also need to save up a bit before I can do anything so... LATER
