Welcome Aboard!:welcome:
Causes A code P0227 may mean that one or more of the following has happened:
TPS not mounted securely
TPS circuit short to ground or another wire
Faulty TPS
Damaged computer (PCM)
Read more at: https://www.obd-codes.com/p0227
Where is throttle position sensor in a 2011 Chevy cruze
Potential causes of a P0299 turbo underboost code include:
Intake (induction) air restriction or leak
Failed or damaged turbocharger (sticking, binding, etc.)
Faulty boost/charge pressure sensor
Read more at: https://www.obd-codes.com/p0299
Cruze/Sonic 1.4L Turbo LUV/LUJ Boost Leak Testing Kits
:moved: to Gen1 1.4L Turbo from Introductions
