Bet it took some time to find the connector pinouts since there are hundreds of these with no index. Here is the circuit diagram showing the ambient light sensor. Pins 1-4 are part of the MVAC circuit.
Looks like an error, line fed to the MVAC controller is ground. with light, the photocell has a low resistance presenting a logical 0 to the BCM that will keep the headlamps off.
The purpose of it is also to kick the AC into high mode during daylight when more cooling is required. If grounded all the time like this circuit shows, will be in high mode all the time.
Darkness presents a high photocell resistance, a logical 1 to the BCM to switch them on.
Are you having a problem with yours?
