So I decided to mount a Samsung Galaxy Tab 2 7inch in my Holden Cruze dash to perform GPS and music duties plus a whole lot more.
I got the idea and product information from wmschoonover in this forum topic http://www.cruzetalk.com/forum/36-audio-electronics/8792-7-android-tablet-dash.html some members in there were asking for a step by step guide, so I took heaps of photos as I was doing it.
The housing kit for the tablet came from this site JY Custom CCRUZ-74 2 Piece Navi & Digital Display Housing. Basically my originally stock stereo still operates exactly the same except for a tablet being connected to it's aux input. This means steering wheel controls remain the same. The kit included an enclosure for the stock stereo information display so it could be relocated to the compartment above the stereo. Then a bezel was included to attach a tablet and install it where the stock display use to be. The kit was designed for a Magellan Roadmate series GPS so some modification was required to make the galaxy fit.
Higher res photos here http://imgur.com/a/le6K6#0
Here I had to sand back the tablet to make it fit with the nav kits bezel. No more warranty
I Pulled the tablets back cover off to ensure I didn't hit anything important when dremeling
A screw hole which will hold the tablet securely in.
Had to modify the dock connector the tablet uses. I really wanted to use a Nexus tab as it uses a micro usb, but the samsung tab's length was just a little shorter so it made a better fit.
Had to cut a little off the tab that holds the bezel into the dash. Later when I had to install it in the car I need to take more off.
Applied fine double sided tape to hold the tablet to the bezel.
Then I carefully aligned the tablet to the bezel and screwed a rubber belt that was provided with the kit. This kept the tab in position and added to the strength of the double sided tape.
It holds together nicely. You can see the tablet is a little bigger then the bezel, this made it a bit hard to install in the dash, I will get to that soon.
This is the power system I used. Again it came with the kit. They call it a smart box and it provides a regulated supply of power. It wires up the same way a headunit would accessory wire, constant 12v, and ground (-). As you can see it already has a female cigarette pulg on it. This allowed me to plug in a 12v usb charger. Make sure you get a 1.5 or 2amp one as the tab will not charge if you were to use a standard 0.5 amp one. The smart box also has a 3.5mm audio cable input and output which cleans the signal of electrical noise.
Now the fun part pulling apart the dash. I recommend following an online guide to pull apart your dash as I did with my Cruze. You can see the stock stereo screen is in the same place the tablet will soon be in.
Pulled the top compartment out. there was two bolts and two little rubber grommets holding it in.
Empty compartment area.
Empty Console
Screwing the stock stereo screen into its new enclosure. Two brackets held it in place and an extension cable was provided with the kit.
The extension cable plugging into the original cable.
Trying to get the tablet in.
Some hackery to the internal sides of the dash. I mainly did this to allow for the dock connector and audio cable to be plugged in.
Empty Console
