Thank you, that's great info bro.
Sent from my LGMS631 using Tapatalk
Source: 22978800 RESERVOIR-SEE NEW PART NUMBER 23377881 for 2014 Chevrolet Cruze - It's #15 in the numbered illustration
does Anyone have a diagram of assembly???
Couple months old, I know - but this is the part being replaced when the heater is throwing the code, yes? Do not have to replace the entire tank?
Yes, this is the part to replace with the P11D7 and/or P20B9 code. As I stated in the OP, this is a single canister-shaped assembly, containing the level sensor, heater, and some other components. The deceptive name "reservoir" has given many people the impression it is the tank; it is not. It basically contains everything except the tank and pump. The reservoir drops into the top of the tank, and the pump mounts to the top of the reservoir after it is installed.Sounds to me like the heater and level sensor are one piece or can not be ordered separately and that the DEF canister is separate . Apparently, the canister is NOT what is going bad in these, but just the heater ( which can not be replaced separately from the level sensor. ) @MP81
I just had this part replaced this past week at my dealer @ 29,000 miles, at NC, under B2B warranty. It took 2 days to get the part. My CEL code was P205B - Reductant Temp. Sensor Out of Range. Work order said; Level & Temp. Emission Reduction Fluid Control Module (incl. filter) part #23377881 replaced. The car did not show any symptoms other than frequent Regen's, which it still does and has been doing for the past 6 months. The Service Rep. thinks this may have something to do with it but I seriously doubt it. We shall see what we shall see. He said the NOx sensor recall is still pending and we will all be notified when the parts are available.Yes, this is the part to replace with the P11D7 and/or P20B9 code. As I stated in the OP, this is a single canister-shaped assembly, containing the level sensor, heater, and some other components. The deceptive name "reservoir" has given many people the impression it is the tank; it is not. It basically contains everything except the tank and pump. The reservoir drops into the top of the tank, and the pump mounts to the top of the reservoir after it is installed.
I think the reservoir is referring to the small sump it comes with - essentially a reservoir for the heater. Sometimes (at least here, don't know for sure about GM) you are limited on what you can call a part, so you go with what fits the best, even if it doesn't at all.Yes, this is the part to replace with the P11D7 and/or P20B9 code. As I stated in the OP, this is a single canister-shaped assembly, containing the level sensor, heater, and some other components. The deceptive name "reservoir" has given many people the impression it is the tank; it is not. It basically contains everything except the tank and pump. The reservoir drops into the top of the tank, and the pump mounts to the top of the reservoir after it is installed.
My guess is that "parts" relate to the ECM tune.He said the NOx sensor recall is still pending and we will all be notified when the parts are available.
I don't see how the SCR could possibly have anything to do with regens, since the SCR is completely downstream of the DPF in the exhaust system.I just had this part replaced this past week at my dealer @ 29,000 miles, at NC, under B2B warranty. It took 2 days to get the part. My CEL code was P205B - Reductant Temp. Sensor Out of Range. Work order said; Level & Temp. Emission Reduction Fluid Control Module (incl. filter) part #23377881 replaced. The car did not show any symptoms other than frequent Regen's, which it still does and has been doing for the past 6 months. The Service Rep. thinks this may have something to do with it but I seriously doubt it. We shall see what we shall see. He said the NOx sensor recall is still pending and we will all be notified when the parts are available.
Do you know which code is turning the CEL on? If you replaced the DEF reservoir, you will clear the P21DD sooner or later, but the P24AE you mentioned will still be there, since it's unrelated. When I replaced my DEF heater, I had P21DD/P20B9 together (both DEF reservoir related), and they cleared on the first engine start after replacement. I have heard of P21DD taking a some miles or a few engine cycles to clear, though.Quick update. Replaced the reservoir today. CEL is still on after around 30-40 miles but it is showing last test passed in the scan tool. I thought I read it can take like 50 miles or more to clear. Any ideas?
The P24AE has not came back on since the original time a couple weeks ago. I cleared codes right after getting the P21DD so I could confirm whether or not I am only dealing with 1 or 2 active codes and the P21DD is the only one that has came back on so far.Do you know which code is turning the CEL on? If you replaced the DEF reservoir, you will clear the P21DD sooner or later, but the P24AE you mentioned will still be there, since it's unrelated. When I replaced my DEF heater, I had P21DD/P20B9 together (both DEF reservoir related), and they cleared on the first engine start after replacement. I have heard of P21DD taking a some miles or a few engine cycles to clear, though.
