1 - 9 of 9 Posts
Hi all, my car has been overheating for possibly three weeks on and off.. I did my best with maintaining with applying the proper fluids- that was not enough, my car overheated on the highway. I pulled over turned my hazard lights on. I waited at 30mins tried to start my car back up and it WOULD NOT START. I noticed it was making a rapid fast ticking sound tried to jump the car and it still not start.. please if you have any feedback or advice on how I can move forward with possibly regaining my cars life back please please reach out..
When you say it won't start, what exactly happens? Does the starter engage and turn the engine at a normal speed?
The first time I tried to start it it just made a really fast ticking noise... I tried to jump it and it would not start either now I just makes a click.
The overheating and non-start sound unrelated.
I’d start with a new battery. If the battery is original, it’s up to 4 years old...it’s possible running the flashers drained the battery so low it won’t jump start anymore.
Once it’s starting/running again, have a mechanic check for stored check engine light codes to help diagnose cooling issues.
Autozone will check your battery and check your codes for free I believe.
Understood! Thank you for all your help
The overheating may have caused the no-start. It is not normal for this car to overheat or need a top-off of coolant. There is probably a leak somewhere, maybe internal to the engine, maybe not. Regardless, an overheating may cause damage that increases the leaks (especially internal leaks - warped head and ruptured head gasket for example) or causes other problems that would result in the car stalling and not restarting.
Thats good feedback as well thank you a ton 17# I will follow-up and let everyone know whats going on with.. I am praying it come back to life =)
1 - 9 of 9 Posts
