If you are looking for a diesel battery, Sears has their battery on sale for $158.99 plus they have a $50 rebate on this battery. Might be worth giving consideration if you need a battery.
Got a link on that rebate? Can't find it....If you are looking for a diesel battery, Sears has their battery on sale for $158.99 plus they have a $50 rebate on this battery. Might be worth giving consideration if you need a battery.
It was a piece of paper at the Sears store, not sure about a link. There was a website, if you call your local Sears automotive center should be able to help you.Got a link on that rebate? Can't find it....
Yes, the AC Delco ones are mostly junk.My Cruze TD has about 60,000 on it, and was manufactured in late 14. However, I get issues where the lights dim when turning and the HVAC fan speed fluctuates. All symptoms of a bad battery. Do the OEM batteries die early?
My negative terminal seems connected tightly. It does not wiggle or move in any way.Yes, the AC Delco ones are mostly junk.
However, negative battery cable issues in the Cruze are very common. Have the battery load tested, but these issues while running sound more like a negative cable issue to me. There is an extended warranty coverage on it to replace the cable free of charge.
The cable itself goes bad.My negative terminal seems connected tightly. It does not wiggle or move in any way.
CTD known to be tough on the factory battery. More info here:My Cruze TD has about 60,000 on it, and was manufactured in late 14. However, I get issues where the lights dim when turning and the HVAC fan speed fluctuates. All symptoms of a bad battery. Do the OEM batteries die early?
Showing mft date as a few months before the car was built, so definitely the original cable.I believe tightness wasn't the issue, had to do with defective crimp or other aspect in the quality of the stock cable. Your cable should have a tag with mfg date. If it's around the date your car was built then replacement is a good place to start. Covered under warranty.
http://www.cruzetalk.com/forum/25-g...al-coverage-14311-negative-battery-cable.html
ok... what makes them so good for any application? They are made by Johnson Controls which also makes Wally World Everstart and a lot of others under different Branding labels. Do they offer a no hassle full 5 year free replacement warranty? Are they amount the highest in the industry for CCA or CA for group size? Does their technology in any way differentiate them from among all the other low cost Brands.Reading Interstate is among the best you can buy for on-road.
The Interstate AGM battery for the Cruze TD is one of the most expensive batteries I've found for it. *check*ok... what makes them so good for any application? They are made by Johnson Controls which also makes Wally World Everstart and a lot of others under different Branding labels. Do they offer a no hassle full 5 year free replacement warranty? Are they amount the highest in the industry for CCA or CA for group size? Does their technology in any way differentiate them from among all the other low cost Brands.
Johnson Controls is know for there run of the mill battery, what characteristics makes them soooo good to standout from top name Brand like NorthStar and Optima who make their own batteries... is it that they are the lowest priced? There is an old saying... you get what you pay for.:hope:
