1 - 4 of 4 Posts
This past weekend I did the first change of my '14 Chevy Cruze Diesel fuel filter. I noticed the replacement I bought on eBay did not match the factory filter, which has clamps. My mechanic said it shouldn't be a problem because it snuggly fit in the filter housing and has also been driving fine without any loss of power having already put 300 miles of fuel through it.
I was curious if any of you knew why there is a difference from aftermarket fuel filters not having those clamps.
Here is a photo of the factory fuel filter with clamps:
Yellow Water Wheel Auto part Rim
· Reverend Red Bull
The fuel filter you removed is GM part number 22937279. There is also a filter that goes under a more recent part number 23456595. The 22937279 filter has the six tabs around the bottom as shown in your photo. 23456595 has a solid ring instead of those tabs. No idea why the change or what difference it makes. I installed the newer part when i did my fuel filter change, and that is when I noticed the difference. There is a thread about it at: http://www.cruzetalk.com/forum/201-...scussion/110705-fuel-filter-part-numbers.html
I think the question many others, in addition to myself, will be curious about is: Where did you get an aftermarket filter for the Cruze Diesel? Any info you can provide regarding cost, source, part numbers, etc. would be helpful, since as far as I am aware, the rest of us have only been aware of the availability of the 2 OEM filters.
[h=1]23456595 - FILTER KIT - General Motors - $74[/h]
[h=1][/h]
23456595 Filter Kit General Motors | eBay
1 - 4 of 4 Posts
