I will just answer all your questions by saying buy a flash scan.I thought you could purchase another vin license to use on the autocal?
Yes you can. Do you have EFI live and a flash scan device as well? Or are you trying to take a tune file saved on the autocal and import it onto another vehicle (VIN) ?Tuners manage the number of available VIN slots they wish their AutoCal devices to hold using their FlashScan device. AutoCal ships with a default maximum VIN slot count set to 1.
AutoCal is configurable to a capacity of 221 VIN licenses. Each VIN License is capable of tuning one supported engine controller. Supported transmission control modules do not require a VIN License.
To ensure VIN Licenses are delivered to you within 10 minutes of processing, your AutoCal Serial number and Auth Code will be validated before you can place your order.
I just found out I have a friend that has efi live and a flashscan v2 that he uses for trucks.Yes you can. Do you have EFI live and a flash scan device as well? Or are you trying to take a tune file saved on the autocal and import it onto another vehicle (VIN) ?
You’d need to tune it to do that. I nor anyone else can really help you there.Would there be any issue applying the tune before it's deleted? I found someone to make a downpipe but I would would like to apply the tune before I drop the car off. Also with the EGR valve and this tune do you leave it connected or does it NOT matter?
I'd be interested in the tuning part if you still do that. I have a 2015 Cruze that is going full limp right now.Maybe I should speak more clearly.
The Cruze can be tuned however you want with the work I've done. Like i said the tuning part is pretty much complete. But I dont do fabricaton. Gotta get that elsewhere.
I don't. Sorry.I'd be interested in the tuning part if you still do that. I have a 2015 Cruze that is going full limp right now.
You need a flashscan to make tunes for an autocal.I got a used autocal V3. It has one vin licence used on it, but it says 0 additional licenses may be purchased for this device?
So whats an autocal for???You need a flashscan to make tunes for an autocal.
EFILive - Documentation / TutorialsSo whats an autocal for???
We did dyno runs stock over peak 220hp. In theory we could have hit higher, but we got stone walled by the transmission. And yeah it got bad.This is awesome stuff.
Snipesy, out of curiosity, what exactly were the mods you had on your CTD with the two example files you attached from your github page, and what sort of results were you seeing at the time (issues, power, etc)? Just trying to figure out where exactly those two files are in the story. I'm assuming completely stock for the 90_emissions.ctz file since all the tables look much more "tame" comparatively speaking.
I can't help but wonder if the load calc table could be found and you could spoof the tcm by altering that table and doing the reverse on your airflow calcs. So the calculated load is lower yet allowed by the MAF/MAP/VE readings etc. So instead of telling the tcm to allow it, it just doesn't get accurate info. That's kinda how you go about DCT tuning on Evos, but I'm unsure if the proper tables are even there to try something similar. I'll have to dig around I suppose.Exceeding that 160hp (or even just adding more area under the curve) led to transmission issues. Even a small amount was enough to cause issues. There is some sort of internal torque model in the TCM which throws a fit when it doesn't match the ECM.
One possibility is lying as much as possible.I can't help but wonder if the load calc table could be found and you could spoof the tcm by altering that table and doing the reverse on your airflow calcs. So the calculated load is lower yet allowed by the MAF/MAP/VE readings etc. So instead of telling the tcm to allow it, it just doesn't get accurate info. That's kinda how you go about DCT tuning on Evos, but I'm unsure if the proper tables are even there to try something similar. I'll have to dig around I suppose.
A European Saab tuner in the Netherlands I was speaking with on email about the AF40 and A20DTH basically said that’s how you tune the transmission by manipulating the torque input from the ECU.One possibility is lying as much as possible.
We touch the MAF signals such that less air flow is present. We then exclusively use injection pulses width to increase fuel.
Then torque to fuel remains stock. And thus the torque calculation looks okay. In addition since we fudged the MAF data the increases torque from our increased fuel will be entirely hidden.
The only problem is having an artificially low MAF may throw some other things off…. But overall the ECM doesn’t give a **** about it. It may just give a code which can be tuned out.
That’s the only approach that could work. And sadly I never tried it.
I should rephrase it a little.A European Saab tuner in the Netherlands I was speaking with on email about the AF40 and A20DTH basically said that’s how you tune the transmission by manipulating the torque input from the ECU.
He didn’t give a lot of details but he did say that he used an 80% throttle input to give full power and it made the kickdown similar stock and allowed full torque acceleration in higher gears.
