Hi folks! Seems like a few people here had a message saying Emission System See Owners Manual Now with a countdown in distance before a max speed limit.
I had absolutely no issue with the car and I got it inside the garage for a cleaning and left it inside overnight with the doors opens and a dehumidifier in the garage and fans. This morning I had the rubbers around the doors treated and wanted to put the car back outside. When I turned it on, this message was on the cluster display. I haven't open the hood nor replaced anything or add any DEF. Went inside, cleaning and that's it.
I scanned it with an OBD2 scanner and the code P2b9A is there. Cannot erase it (it comes back) and no check engine.
In the owner's manual, it says "In some cases this message will clear itself, indicating that the emission system was able to correct the condition." but nothing (obviously) on the error code or what the problem might be.
Being confined because of the COVID, I cannot go see a mechanic anytime soon. I am trying to get some help from you if anyone knows anything!
Thanks!
Thanks!
