1 - 20 of 28 Posts
I have grown accustomed to the shift to neutral at a stop in the CTD. I drove a 1.4 2lt and it does not have this. the owners manual says its to save wear and tear plus ive heard to save some fuel to the engine doesn't have to fight the TC during the stop time.
i would personally take it out if i could ( keep it in manual 1 and good to go). how many others here like or don't like it?
getting off the line when needed would be way faster if it stayed in gear, plus way better when up hills. i would imagine if my car crawled backwards on a hill and hits a car behind me id be at fault right?
COTM Winner
I never put it into neutral - unless I know that the brakes probably some heat coming up to the stop - but that goes for anything I drive, or if I feel I need to give my foot a rest.
I would never shift it to neutral. Have no idea what benefit would be. Seems to be overthinking it here to me. Just my 2 cents.
2001-2002 model year AW50-55SN's (Volvo, Nissan, etc) had this stop-neutral feature programmed into the transmissions. It wore them out in a much shorter timeframe than the old AW50-42LE's that came before them.
So far, the GM and Aisin transmissions used in Cruzen have not seemed to have ill effects from it - some are upwards of 150-200K on automatics without issue.
I suspect that may have something to do with the "pseudo neutral" state it goes into. I'm not well versed in automatic transmissions, but I do know that my Cruze was definitely not in a full neutral state when stopped. It was like half neutral and half drive. I could get it to creep ever so slowly before feeling the bump to engage drive again and I could be held on a small hill by this weak force. Also verified by fuel usage - in M1, was about .3 gallons per hour - D, .25gph - neutral, .22gph. So it was not in full neutral when stopped in drive.
SPACED, when i got a loaner 1.4 i took my normal daily routines and i let off the brake and it crept imidiatly vs the delay and sligh push feel the CTd has.
i don't indy the cruze does it for me lol. what i would like to know is why use this feture. does it really save wear and tear? does it really help city mpg?
Every auto Cruze I've had definitely drops into neutral, but the gas ones are very quick to get back into gear (usually with a very slightly noticeable little thump, unless you catch it off-guard and move from brake to gas very quickly).
Discussion Starter · #11 ·
ok then, i must have not noticed then. the CTd is very pronounced. i have to slow my foot from brake to gas because if not then i catch it getting into gear.
he's not putting it in N
his car does it automatically, so does yours
Oh ok, I misread the post.....no big deal.
I noticed it a lot when I first got my car, but now don't even think about it.
COTM Winner
I do enjoy the noticeable downshifting while driving the car - engine braking it utilized quite a bit.
Discussion Starter · #17 ·
i have also grown accustomed to the shift to neutral, but there are moments i let off the brake and get on the gas to quick and it just don't feel right.
For the last few months now I've noticed that once the car is up to op. temp. whenever I'm at a light, etc. and the car shifts into neutral (automatic mode), I get a HUGE delay shifting back into first gear. The car will almost feel like it's stalled and then boom, it will slam into gear. I cringe at what it's doing to my trans. I'm debating on taking it into the dealer or not. It's that bad. Only 63K miles on it.
Have you changed the fluid? Sounds like it's time if you haven't.
1 - 20 of 28 Posts
