P0133 is an O2 sensor that upon testing, often includes replacing both the faulty O2 sensor and an EGR valve + mounting plate in order to achieve resolution.
They should be the same.Are the codes with a tune going to be different than codes without a tune? I would think that there should be 2 threads on this topic - codes thrown by those who are running stock and codes thrown by those who have tunes. I would think many of the codes that are thrown by those with tunes would not be relevant to those running stock due to different operational parameters. That being said, this thread is a great idea.
P205B resolved. Temperature sensor in the DEF reservoir was malfunctioning, reporting 170 degrees when actual temperature was 62. Not sure how the computer knows this was an issue, but the entire DEF reservoir was replaced.
Techs have found that the most common cause of this code is unmetered air coming in from pcv heater at air intake. A new air intake is being released next quarter to permanently fix this issue.P0133 is an O2 sensor that upon testing, often includes replacing both the faulty O2 sensor and an EGR valve + mounting plate in order to achieve resolution.
Sounds like a positive development in solving one of these emissions issues. Glad they've made some progress on this. For now, the O2/EGR fix they did on mine seems to be holding up, but I'll know where to look if the code returns. Any idea which warranty this repair (in the event someone needs it) would fall under - powertrain, emissions, or just the 36k B2B warranty?Techs have found that the most common cause of this code is unmetered air coming in from pcv heater at air intake. A new air intake is being released next quarter to permanently fix this issue.
Did it give you warning prior being full or is it just suddenly saying its "full"?P2463 - Diesel Particulate Filter is Full - Only a manual regen can clear this code.
Any trouble starting cold? Looks like it could be a glow plug error, but I am not 100% sure about that. How many miles on it?I am getting a P161A code. Can anyone help with what that is? 2014 Cruze diesel.
Here's what mine did at that temp:31,000 miles. It was down to -10F and it took 2 trys to start. It cranked about 10 seconds before starting. What would be normal?
Yes it is31,000 miles. It was down to -10F and it took 2 trys to start. It cranked about 10 seconds before starting. What would be normal?
