1 - 10 of 10 Posts
I drove a 2015 LTZ today & could not believe the harder ride between it & my 2014 2LT. I thought the 2LT & the LTZ had the same suspension. The LTZ has 18 versus 17 inch rim tires. Could I put a 17 inch rim tire on the LTZ?
Same circumference (first number in tire size). For example, 2014 Cruze's shared the 225 circumference across 17 inch and 18 inch rims. My '14 Cruze 1LT has 215 tire circumference though since it is a 16 inch rim.
The first number is the width of the tire in millimetres at cross section.
The second number is the percentage of the height of the tire to the width of the tire; again at cross section.
The third number is the diameter of the wheel in inches.
All three numbers factored together will give you the diameter of the wheel/tire package.
Circumference is calculated by multiplying the diameter of the wheel/tire package by Pi (3.14...)
1 - 10 of 10 Posts
