Is there a way to easily disable the EGR on the Gen 2 diesel engines? Something simple like unplugging a connector to the EGR valve that leaves it closed?
I don't think there are any solutions out yet. It would require an engine tune if you were to delete the EGR.Is there a way to easily disable the EGR on the Gen 2 diesel engines? Something simple like unplugging a connector to the EGR valve that leaves it closed?
I'm just wanting to do something like unplug the EGR valve if it defaults to the closed position. I'm willing to put up with a Check Engine Light for now, until an engine tune is available.It would require an engine tune if you were to delete the EGR.
But until you try it, you don't know if it's a CEL or a 'reduced power in 50 miles' warning.I'm just wanting to do something like unplug the EGR valve if it defaults to the closed position. I'm willing to put up with a Check Engine Light for now, until an engine tune is available.
I can wire in a switch to consistently reset it. A friend of mine has that on his Jeep Liberty CRD. It's a switch in the cabin where you leave the EGR enabled for about 30 seconds after starting the engine and the ECU apparently only checks EGR functioning right then. After that short time period you can turn the EGR off and drive the car with no CEL showing up.But until you try it, you don't know if it's a CEL or a 'reduced power in 50 miles' warning.
Better fuel economy and to keep from gunking up the intake.Why disable the EGR?
I wouldn't do that.I'm just wanting to do something like unplug the EGR valve if it defaults to the closed position. I'm willing to put up with a Check Engine Light for now, until an engine tune is available.
Oh how I miss VagcomI wouldn't do that.
I tried doing this with my TDI. Forced the valve closed with Ross Tech software. The ECU retarded the ignition timing and made it run like ****, lost about 10 MPGs.
You would need to re-map the fuel and boost to take advantage of the extra O2 in the clean airstream.
Ignition timing? You're using terms from spark ignition engines.I tried doing this with my TDI. Forced the valve closed with Ross Tech software. The ECU retarded the ignition timing and made it run like ****, lost about 10 MPGs.
Sorry Barry, I mis-spelled injection timing, but spell check corrected it to ignition.Ignition timing? You're using terms from spark ignition engines.
Diesel engines run O2 rich at all times of operation. EGR is used to reduce O2 content to avoid NOx production. A total elimination of EGR means the same amount of fuel is being injected (if you didn't change fueling) and there should be no change in operation other than avoiding your intake being sooted up with exhaust gas.
There has to be something else going on with your TDI tuning.
I guess your dad got one of the few good Ram Ecodiesels. I wouldn’t buy one of those things for 50% off retail.Hi there,
I too am looking for a solution to this. Green Diesel Eng. seems to be the most hopeful promise. I've visited up there a few times already and brought it to their attention there is a market for that tune. My Dad own a '14 Ecodiesel by RAM. Hauls TT, Airstreams, Boats, Cars with it as a business. Has the EGR tune they offer for it, loves it, no trouble with it at all. 450k on the truck so far - guy's a madman. Moderates for https://www.ram1500diesel.com and loves all things Ecodiesel. He turned me on to the Cruze TD as an option for my business. Fingers crossed we get our version of the tune with a warranty on it sometime soon.
All The Best,
Gabriel
1. Break ECU encryption.What's needed is to have a tune to set the EGR to a Dynamic operation = less of it, alot less.
How does higher DEF usage ruin the catalyst?higher NOX values with cause DEF usage to be ecxessive and eventually damage the SCR
I was told excessive DEF usage would cause crystallization inside the catalyst and restrict flow.How does higher DEF usage ruin the catalyst?higher NOX values with cause DEF usage to be ecxessive and eventually damage the SCR
Yes, but you fail to realize that by tuning the ECU and disabling EGR, NOx concentrations will increase substantially as you will have a leaner mixture and and more complete combustion. As a result of complete combustion, less soot is generated so the Regen time between DEF cleanings will increase.Perhaps only if it's excessive related to the amount of exhaust flowing through it (and thus, NOx).
There are NOx sensors before and after the SCR that would adjust the amount of DEF in accordance to the NOx "content" of the exhaust gasses.
