So you're going to pay a lot more for looks - might as well add a fart can and stickers to your car. Good luck with drilled rotors and I hope they don't crack for you when you need them most.And because of that, I'll be putting slotted/cross drilled rotors on my car. Because I don't heat them up enough to even get remotely close to their limit.
And derail it back to trash talk. This discussion was actually going pretty good too.So you're going to pay a lot more for looks - might as well add a fart can and stickers to your car. Good luck with drilled rotors and I hope they don't crack for you when you need them most.
My bad. My experience with Cruze brakes probably differs a LOT from the gas models...That mountain must not have been like the two my Wife goes over every day to work, and back home. I've had both of our Cruze's shaking badly going down either side. This is with both stock brakes, and EBC blank rotors with Hawk HPS pads that were bedded to the letter of Hawk's instructions.
I start at roughly 30-40 mph at the top, and by the bottom you have to use the brakes a lot because these cars just will not hold themselves back. When you get behind someone it's even worse. You can let them get ahead of you at the top, but by the middle to bottom of the mountain you have to be all over the brakes because they're poking along at 25, and the Cruze acts like a run away train because there's no compression braking.
For me personally I see no con's to the slotted rotors. I've had them before with no problems as far as brake shake compared to blank rotors. Now if I lived out where it's flat I definitely believe that blank rotors would suit me just fine.
Not saying your wrong, I was just stating how my experience has been different so far.My bad. My experience with Cruze brakes probably differs a LOT from the gas models...
So as far as the shaking goes with the pad deposits, did you Rebed afterwards to remove the deposits?That mountain must not have been like the two my Wife goes over every day to work, and back home. I've had both of our Cruze's shaking badly going down either side. This is with both stock brakes, and EBC blank rotors with Hawk HPS pads that were bedded to the letter of Hawk's instructions.
Sent from my Droid Ultra
No sir, was not aware that doing that would fix anything? Too late now to try it again?So as far as the shaking goes with the pad deposits, did you Rebed afterwards to remove the deposits?
Good question, do they list them as front or rear? Gas or Diesel?On a side note here, what size are the front rotors on the Cruze? I'm getting two different sizes at 10.9" and 11.8".
Listed as front, no other info. I was told by Smurfenstein that the diesel has 11.8" rotors, and the gas cars have the 10.9".Good question, do they list them as front or rear? Gas or Diesel?
That's what I have always experienced is that bedding the rotors after a trip like that gets deposit build up gets you a *clean* rotor. Basically removes the built up pad deposit and smooths it back out.No sir, was not aware that doing that would fix anything? Too late now to try it again?
