DIY Bone chilling AC
48937 Views 25 Replies 10 Participants Last post by  blsnelling
18
Myself and others on this board have experienced what we could call “less than great” performance from their Cruzens air conditioning system. My AC would do a fair job of keeping the cabin cool at best in hot and humid weather. All of my prior cars have had bone chilling systems when properly set-up, and I frankly needed more from my current system in the cruze.
First there are different approaches toward this project. Some say just go get a liquid refrigerant “charge system” from the parts store, and top off the charge and be done with it. As this is an option it only gives you limited insight into the system, and leaves you guessing at the total charge.
Here is my approach.
Assembly all the tools and supplies needed to get the job done. I perform all my own repair and maintenance work to not only my home, but my vehicles also. I already own a set of compound 134a gauges and hose set. You can pick these up at an auto parts store for approx. $90-$100, and most have had good results with the “Harbor freight special” for approx $50. I procured my set about a year ago from Advanced Auto for a really good deal, so I can’t personally vouch for the cheaper set
. Technology Fashion accessory Auto part Automotive lighting Vehicle
You may find different opinions in regards to brand and composition of 134a. I personally used “straight” 134a without any additives.
Product Material property Chemical compound Liquid Drink
There is a pressure temperature relationship with all refrigerants. It is essential you establish current ambient temperature and humidity levels prior to starting. As you can see I used a multi-meter set to the Temperature setting as degrees. I checked my local weather station app for the current humidity levels.
Measuring instrument Tool Meter
My readings were 82 degrees with approximately 62% humidity.
I retrieved the necessary charts and information relevant to the job from the service manual.
Text Font Document Paper Receipt
Text Font Document Receipt Paper
Text Font Paper Document
Note: For my readings the low pressure side range is (30-45 PSI) and the high pressure side range is (187-232 PSI) and vent discharge minimum temp should be 59 degrees (that’s pathetic).
Note: Vehicle should be warmed up to operating temperature, no supplemental fans to move air across the condenser, AC on highest setting, recirculate enabled, and all discharge vents open, with your reading taken from the left center stack. Run AC for 5 minutes with the driver window opened approx 5-8 inches.
Probe placement (left) Actual reading taken prior to charge increase 47 degrees (right)
Vehicle Car Chevrolet cruze Center console Multimedia
Vehicle Car Yellow Subcompact car Family car
My goal is increase the 134a charge to within the “upper range” of the specs and lower vent discharge temps.
Pop the hood and locate the low and high pressure service ports (low pressure left) high pressure (right). Both are on the passenger side just behind and below the air box.
Auto part Vehicle Technology Automotive exterior Car
Auto part Vehicle Engine Car Automotive exterior
Unscrew the plastic caps and put them safely aside.
Fashion the gauge set as pictured. Make a loop with the yellow charge/vac line (2nd from left), and make sure all valves are closed and o-ringed connections tight. (Note: I will be using a small 12oz charge that hooks directly to the gauge cluster((pictured far left). If you own or have access to a larger charge cylinder you may use the yellow charge line directly) The hoses and connections are not only color coded, but labeled, and different sizes so it's almost idiot proof.
Tire Machine Auto part Technology Wire
Technology
Technology Auto part Electronic device Audio equipment Gas
Bearing Ball bearing Auto part Hardware accessory
Hook up the low and high pressure "quick connects". They operate on the same principles as compressed air fittings, and couplers.
Vehicle Wire Auto part Electrical wiring Engine
With all connections made and the AC running as described above open low, and high side valves and obtain your reading.
Product Gauge Auto part Measuring instrument
As you see my readings are "within" spec low side 32 and high side 210ish, however not in the upper range.
Note: Also if your gauge set contains a site glass you can view the condition of your refrigerant, dye, and oil. (GM puts puts dye in from the factory)
I added charge to the LOW PRESSURE side only (very important) a little at a time and brought pressures up to approx 42 low side and 235 high side. This favors the higher values within the given specifications.
Results you may ask?
Vehicle Car Mode of transport Car seat Family car
A 12 degree drop in vent discharge temps.
I now can drive around without having to have the AC on full blast and be very cool and comfortable!
Close all valves, and disconnect your fittings, and don't forget to replace the plastic caps back over the service ports.
Keep in mind some mechanical inclination is required to do this, and I in no way will be held responsible for damage or injury. Also note it is federal law that prevents directly venting 134a into the atmosphere. DO NOT vent 134a into the atmosphere!
Thanks and I hope this helps fellow Cruze talkers!
Reactions: 5
21 - 26 of 26 Posts
[SIZE=-1]Temperature/Pressure Chart[/SIZE]
[SIZE=-1]Temp F°[/SIZE][SIZE=-1]R-12[/SIZE][SIZE=-1]R-134a[/SIZE][SIZE=-1]HOT SHOT[/SIZE][SIZE=-1]MP-39[/SIZE][SIZE=-1]MP-66[/SIZE][SIZE=-1]FX-56[/SIZE][SIZE=-1]FRIGC*[/SIZE][SIZE=-1]GHG-X4*[/SIZE][SIZE=-1]R-406a[/SIZE]
[SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE][SIZE=-1]BP / DP [/SIZE]
[SIZE=-1]-45[/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1][SUB]18.8[/SUB] [SUP]20.0[/SUP][/SIZE][SIZE=-1][SUB]11.2[/SUB] [SUP]18.4[/SUP][/SIZE][SIZE=-1][/SIZE]
[SIZE=-1]-40[/SIZE][SIZE=-1]11.0[/SIZE][SIZE=-1][/SIZE][SIZE=-1][SUB]7.7[/SUB] [SUP]15.3[/SUP][/SIZE][SIZE=-1][/SIZE][SIZE=-1][SUB]7.0[/SUB] [SUP]12.9[/SUP][/SIZE][SIZE=-1]
[/SIZE]
[SIZE=-1][SUB]17.2[/SUB] [SUP]18.4[/SUP][/SIZE][SIZE=-1][SUB]8.8[/SUB] [SUP]16.8[/SUP][/SIZE][SIZE=-1][SUB]7.0[/SUB] [SUP]17.0[/SUP][/SIZE]
[SIZE=-1]-35[/SIZE][SIZE=-1]8.4[/SIZE][SIZE=-1][/SIZE][SIZE=-1][SUB]4.7[/SUB] [SUP]13.2[/SUP][/SIZE][SIZE=-1]
[/SIZE]
[SIZE=-1][SUB]3.8[/SUB] [SUP]10.2[/SUP][/SIZE][SIZE=-1]
[/SIZE]
[SIZE=-1][SUB]15.2[/SUB] [SUP]16.8[/SUP][/SIZE][SIZE=-1][SUB]6.0[/SUB] [SUP]14.8[/SUP][/SIZE][SIZE=-1][SUB]5.8[/SUB] [SUP]15.0[/SUP][/SIZE]
[SIZE=-1]-30[/SIZE][SIZE=-1]5.5[/SIZE][SIZE=-1]9.9[/SIZE][SIZE=-1][SUB]1.4[/SUB] [SUP]10.7[/SUP][/SIZE][SIZE=-1]
[/SIZE]
[SIZE=-1][SUB]0.3[/SUB] [SUP]7.3[/SUP][/SIZE][SIZE=-1][SUB]0.2[/SUB] [SUP]9.9[/SUP][/SIZE][SIZE=-1][SUB]13.2[/SUB] [SUP]14.8[/SUP][/SIZE][SIZE=-1][SUB]3.8[/SUB] [SUP]12.8[/SUP][/SIZE][SIZE=-1][SUB]3.2[/SUB] [SUP]12.8[/SUP][/SIZE]
[SIZE=-1]-25[/SIZE][SIZE=-1]2.3[/SIZE][SIZE=-1]6.9[/SIZE][SIZE=-1][SUB]1.1[/SUB] [SUP]8.1[/SUP][/SIZE][SIZE=-1]
[/SIZE]
[SIZE=-1][SUB]1.8[/SUB] [SUP]4.2[/SUP][/SIZE][SIZE=-1][SUB]1.8[/SUB] [SUP]7.0[/SUP][/SIZE][SIZE=-1][SUB]10.8[/SUB] [SUP]12.8[/SUP][/SIZE][SIZE=-1][SUB].4[/SUB] [SUP]10.4[/SUP][/SIZE][SIZE=-1][SUB]1.9[/SUB] [SUP]10.4[/SUP][/SIZE]
[SIZE=-1]-20[/SIZE][SIZE=-1].6[/SIZE][SIZE=-1]3.7[/SIZE][SIZE=-1][SUB]3.1[/SUB] [SUP]5.1[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]3.0[/SUP][/SIZE][SIZE=-1][SUB]3.9[/SUB] [SUP]0.6[/SUP][/SIZE][SIZE=-1][SUB]3.9[/SUB] [SUP]3.8[/SUP][/SIZE][SIZE=-1][SUB]8.0[/SUB] [SUP]10.4[/SUP][/SIZE][SIZE=-1][SUB]2.4[/SUB] [SUP]7.6[/SUP][/SIZE][SIZE=-1][SUB]2.3[/SUB] [SUP]7.6[/SUP][/SIZE]
[SIZE=-1]-15[/SIZE][SIZE=-1]2.5[/SIZE][SIZE=-1].6[/SIZE][SIZE=-1][SUB]4.9[/SUB] [SUP]2.0[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]1.0[/SUP][/SIZE][SIZE=-1][SUB]6.2[/SUB] [SUP]1.6[/SUP][/SIZE][SIZE=-1][SUB]6.2[/SUB] [SUP]0.3[/SUP][/SIZE][SIZE=-1][SUB]5.2[/SUB] [SUP]7.6[/SUP][/SIZE][SIZE=-1][SUB]4.5[/SUB] [SUP]4.4[/SUP][/SIZE][SIZE=-1][SUB]4.4[/SUB] [SUP]4.6[/SUP][/SIZE]
[SIZE=-1]-10[/SIZE][SIZE=-1]4.5[/SIZE][SIZE=-1]1.9[/SIZE][SIZE=-1][SUB]7.6[/SUB] [SUP]0.8[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]3.0[/SUP][/SIZE][SIZE=-1][SUB]8.7[/SUB] [SUP]3.8[/SUP][/SIZE][SIZE=-1][SUB]8.7[/SUB] [SUP]1.7[/SUP][/SIZE][SIZE=-1][SUB]2.0[/SUB] [SUP]4.4[/SUP][/SIZE][SIZE=-1][SUB]6.8[/SUB] [SUP]1.2[/SUP][/SIZE][SIZE=-1][SUB]6.7[/SUB] [SUP]1.4[/SUP][/SIZE]
[SIZE=-1]-5[/SIZE][SIZE=-1]6.8[/SIZE][SIZE=-1]4.0[/SIZE][SIZE=-1][SUB]10.2[/SUB] [SUP]2.7[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]5.0[/SUP][/SIZE][SIZE=-1][SUB]11.5[/SUB] [SUP]6.1[/SUP][/SIZE][SIZE=-1][SUB]11.4[/SUB] [SUP]3.8[/SUP][/SIZE][SIZE=-1][SUB]0.9[/SUB] [SUP]1.2[/SUP][/SIZE][SIZE=-1][SUB]9.3[/SUB] [SUP]1.2[/SUP][/SIZE][SIZE=-1][SUB]9.2[/SUB] [SUP]1.5[/SUP][/SIZE]
[SIZE=-1]0[/SIZE][SIZE=-1]8.2[/SIZE][SIZE=-1]6.5[/SIZE][SIZE=-1][SUB]13.0[/SUB] [SUP]4.9[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]7[/SUP][/SIZE][SIZE=-1][SUB]14.5[/SUB] [SUP]8.7[/SUP][/SIZE][SIZE=-1][SUB]14.4[/SUB] [SUP]6.1[/SUP][/SIZE][SIZE=-1][SUB]2.9[/SUB] [SUP]1.2[/SUP][/SIZE][SIZE=-1][SUB]12.0[/SUB] [SUP]3.2[/SUP][/SIZE][SIZE=-1][SUB]11.9[/SUB] [SUP]3.5[/SUP][/SIZE]
[SIZE=-1]5[/SIZE][SIZE=-1]11.9[/SIZE][SIZE=-1]9.1[/SIZE][SIZE=-1][SUB]16.1[/SUB] [SUP]7.3[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]9[/SUP][/SIZE][SIZE=-1][SUB]17.8[/SUB] [SUP]11.5[/SUP][/SIZE][SIZE=-1][SUB]17.6[/SUB] [SUP]18.6[/SUP][/SIZE][SIZE=-1][SUB]5.1[/SUB] [SUP]3.2[/SUP][/SIZE][SIZE=-1][SUB]15.0[/SUB] [SUP]4.5[/SUP][/SIZE][SIZE=-1][SUB]14.9[/SUB] [SUP]5.8[/SUP][/SIZE]
[SIZE=-1]10[/SIZE][SIZE=-1]14.6[/SIZE][SIZE=-1]11.9[/SIZE][SIZE=-1][SUB]19.5[/SUB] [SUP]9.9[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]12.5[/SUP][/SIZE][SIZE=-1][SUB]21.3[/SUB] [SUP]14.5[/SUP][/SIZE][SIZE=-1][SUB]21.1[/SUB] [SUP]11.4[/SUP][/SIZE][SIZE=-1][SUB]7.4[/SUB] [SUP]5.4[/SUP][/SIZE][SIZE=-1][SUB]18.2[/SUB] [SUP]7.8[/SUP][/SIZE][SIZE=-1][SUB]18.1[/SUB] [SUP]8.2 [/SUP][/SIZE]
[SIZE=-1]15[/SIZE][SIZE=-1]17.7[/SIZE][SIZE=-1]15.0[/SIZE][SIZE=-1][SUB]23.1[/SUB] [SUP]12.7[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]15.5[/SUP][/SIZE][SIZE=-1][SUB]25.1[/SUB] [SUP]17.8[/SUP][/SIZE][SIZE=-1][SUB]24.9[/SUB] [SUP]14.4[/SUP][/SIZE][SIZE=-1][SUB]10.0[/SUB] [SUP]7.8[/SUP][/SIZE][SIZE=-1][SUB]21.7[/SUB] [SUP]10.5[/SUP][/SIZE][SIZE=-1][SUB]21.5[/SUB] [SUP]10.8[/SUP][/SIZE]
[SIZE=-1]20[/SIZE][SIZE=-1]21.0[/SIZE][SIZE=-1]18.4[/SIZE][SIZE=-1][SUB]26.9[/SUB] [SUP]15.8[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]19.0[/SUP][/SIZE][SIZE=-1][SUB]29.3[/SUB] [SUP]21.4[/SUP][/SIZE][SIZE=-1][SUB]29.0[/SUB] [SUP]17.6[/SUP][/SIZE][SIZE=-1][SUB]12.9[/SUB] [SUP]10.4[/SUP][/SIZE][SIZE=-1][SUB]25.4[/SUB] [SUP]13.3[/SUP][/SIZE][SIZE=-1][SUB]25.3[/SUB] [SUP]13.7[/SUP][/SIZE]
[SIZE=-1]25[/SIZE][SIZE=-1]24.6[/SIZE][SIZE=-1]22.1[/SIZE][SIZE=-1][SUB]31.1[/SUB] [SUP]19.1[/SUP][/SIZE][SIZE=-1][SUB]~[/SUB] [SUP]23.0[/SUP][/SIZE][SIZE=-1][SUB]33.7[/SUB] [SUP]25.3[/SUP][/SIZE][SIZE=-1][SUB]33.4[/SUB] [SUP]21.2[/SUP][/SIZE][SIZE=-1][SUB]16.0[/SUB] [SUP]13.2[/SUP][/SIZE][SIZE=-1][SUB]29.5[/SUB] [SUP]16.5[/SUP][/SIZE][SIZE=-1][SUB]29.3[/SUB] [SUP]16.8[/SUP][/SIZE]
[SIZE=-1]30[/SIZE][SIZE=-1]28.5[/SIZE][SIZE=-1]26.1[/SIZE][SIZE=-1][SUB]35.6[/SUB] [SUP]23.1[/SUP][/SIZE][SIZE=-1][SUB]36.0[/SUB] [SUP]27.0[/SUP][/SIZE][SIZE=-1][SUB]38.4[/SUB] [SUP]29.5[/SUP][/SIZE][SIZE=-1][SUB]38.1[/SUB] [SUP]25.0[/SUP][/SIZE][SIZE=-1][SUB]19.3[/SUB] [SUP]16.3[/SUP][/SIZE][SIZE=-1][SUB]33.8[/SUB] [SUP]19.8[/SUP][/SIZE][SIZE=-1][SUB]33.6[/SUB] [SUP]20.2[/SUP][/SIZE]
[SIZE=-1]35[/SIZE][SIZE=-1]32.6[/SIZE][SIZE=-1]30.4[/SIZE][SIZE=-1][SUB]40.5[/SUB] [SUP]26.7[/SUP][/SIZE][SIZE=-1][SUB]41.0[/SUB] [SUP]31.0[/SUP][/SIZE][SIZE=-1][SUB]43.5[/SUB] [SUP]34.1[/SUP][/SIZE][SIZE=-1][SUB]43.2[/SUB] [SUP]29.2[/SUP][/SIZE][SIZE=-1][SUB]22.9[/SUB] [SUP]19.7[/SUP][/SIZE][SIZE=-1][SUB]38.5[/SUB] [SUP]23.5[/SUP][/SIZE][SIZE=-1][SUB]38.2[/SUB] [SUP]23.9[/SUP][/SIZE]
[SIZE=-1]40[/SIZE][SIZE=-1]37.0[/SIZE][SIZE=-1]34.1[/SIZE][SIZE=-1][SUB]45.6[/SUB] [SUP]30.9[/SUP][/SIZE][SIZE=-1][SUB]45.0[/SUB] [SUP]36.0[/SUP][/SIZE][SIZE=-1][SUB]49.1[/SUB] [SUP]39.0[/SUP][/SIZE][SIZE=-1][SUB]48.6[/SUB] [SUP]33.6[/SUP][/SIZE][SIZE=-1][SUB]26.8[/SUB] [SUP]23.3[/SUP][/SIZE][SIZE=-1][SUB]43.5[/SUB] [SUP]27.5[/SUP][/SIZE][SIZE=-1][SUB]43.2[/SUB] [SUP]27.8[/SUP][/SIZE]
[SIZE=-1]45[/SIZE][SIZE=-1]41.7[/SIZE][SIZE=-1]40.1[/SIZE][SIZE=-1][SUB]51.2[/SUB] [SUP]35.5[/SUP][/SIZE][SIZE=-1][SUB]52.0[/SUB] [SUP]40.0[/SUP][/SIZE][SIZE=-1][SUB]55.0[/SUB] [SUP]44.3[/SUP][/SIZE][SIZE=-1][SUB]54.4[/SUB] [SUP]38.5[/SUP][/SIZE][SIZE=-1][SUB]31.0[/SUB] [SUP]27.2[/SUP][/SIZE][SIZE=-1][SUB]48.8[/SUB] [SUP]31.7[/SUP][/SIZE][SIZE=-1][SUB]48.5[/SUB] [SUP]32.1[/SUP][/SIZE]
[SIZE=-1]50[/SIZE][SIZE=-1]46.7[/SIZE][SIZE=-1]45.5[/SIZE][SIZE=-1][SUB]57.0[/SUB] [SUP]40.3[/SUP][/SIZE][SIZE=-1][SUB]58.0[/SUB] [SUP]46.0[/SUP][/SIZE][SIZE=-1][SUB]61.2[/SUB] [SUP]49.9[/SUP][/SIZE][SIZE=-1][SUB]60.6[/SUB] [SUP]43.6[/SUP][/SIZE][SIZE=-1][SUB]35.6[/SUB] [SUP]31.5[/SUP][/SIZE][SIZE=-1][SUB]54.5[/SUB] [SUP]36.3[/SUP][/SIZE][SIZE=-1][SUB]54.2[/SUB] [SUP]38.7[/SUP][/SIZE]
[SIZE=-1]55[/SIZE][SIZE=-1]52.0[/SIZE][SIZE=-1]51.3[/SIZE][SIZE=-1][SUB]63.3[/SUB] [SUP]45.5[/SUP][/SIZE][SIZE=-1][SUB]64[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]67.9[/SUB] [SUP]56.0[/SUP][/SIZE][SIZE=-1][SUB]67.2[/SUB] [SUP]49.2[/SUP][/SIZE][SIZE=-1][SUB]40.4[/SUB] [SUP]36.0[/SUP][/SIZE][SIZE=-1][SUB]60.5[/SUB] [SUP]41.3[/SUP][/SIZE][SIZE=-1][SUB]60.2[/SUB] [SUP]41.6[/SUP][/SIZE]
[SIZE=-1]60[/SIZE][SIZE=-1]57.7[/SIZE][SIZE=-1]57.5[/SIZE][SIZE=-1][SUB]70.0[/SUB] [SUP]51.2[/SUP][/SIZE][SIZE=-1][SUB]71.0[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]75.0[/SUB] [SUP]62.5[/SUP][/SIZE][SIZE=-1][SUB]74.2[/SUB] [SUP]55.2[/SUP][/SIZE][SIZE=-1][SUB]45.6[/SUB] [SUP]40.9[/SUP][/SIZE][SIZE=-1][SUB]67.0[/SUB] [SUP]45.5[/SUP][/SIZE][SIZE=-1][SUB]66.6[/SUB] [SUP]46.9[/SUP][/SIZE]
[SIZE=-1]65[/SIZE][SIZE=-1]63.8[/SIZE][SIZE=-1]64.1[/SIZE][SIZE=-1][SUB]77.8[/SUB] [SUP]57.2[/SUP][/SIZE][SIZE=-1][SUB]78[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]82.7[/SUB] [SUP]69.4[/SUP][/SIZE][SIZE=-1][SUB]81.7[/SUB] [SUP]61.5[/SUP][/SIZE][SIZE=-1][SUB]51.2[/SUB] [SUP]46.1[/SUP][/SIZE][SIZE=-1][SUB]73.9[/SUB] [SUP]52.2[/SUP][/SIZE][SIZE=-1][SUB]73.4[/SUB] [SUP]52.5[/SUP][/SIZE]
[SIZE=-1]70[/SIZE][SIZE=-1]70.2[/SIZE][SIZE=-1]71.2[/SIZE][SIZE=-1][SUB]84.6[/SUB] [SUP]63.6[/SUP][/SIZE][SIZE=-1][SUB]86[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]90.7[/SUB] [SUP]76.8[/SUP][/SIZE][SIZE=-1][SUB]89.6[/SUB] [SUP]68.4[/SUP][/SIZE][SIZE=-1][SUB]57.2[/SUB] [SUP]51.7[/SUP][/SIZE][SIZE=-1][SUB]81.2[/SUB] [SUP]58.3[/SUP][/SIZE][SIZE=-1][SUB]80.6[/SUB] [SUP]58.6[/SUP][/SIZE]
[SIZE=-1]75[/SIZE][SIZE=-1]77.0[/SIZE][SIZE=-1]78.8[/SIZE][SIZE=-1][SUB]92.7[/SUB] [SUP]70.5[/SUP][/SIZE][SIZE=-1][SUB]93[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]99.3[/SUB] [SUP]84.7[/SUP][/SIZE][SIZE=-1][SUB]98.0[/SUB] [SUP]75.6[/SUP][/SIZE][SIZE=-1][SUB]63.5[/SUB] [SUP]57.7[/SUP][/SIZE][SIZE=-1][SUB]88.9[/SUB] [SUP]64.7[/SUP][/SIZE][SIZE=-1][SUB]88.3[/SUB] [SUP]65.0[/SUP][/SIZE]
[SIZE=-1]80[/SIZE][SIZE=-1]84.2[/SIZE][SIZE=-1]86.8[/SIZE][SIZE=-1][SUB]101.1[/SUB] [SUP]77.8[/SUP][/SIZE][SIZE=-1][SUB]103[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]108.3[/SUB] [SUP]93.1[/SUP][/SIZE][SIZE=-1][SUB]106.9[/SUB] [SUP]83.4[/SUP][/SIZE][SIZE=-1][SUB]70.3[/SUB] [SUP]64.1[/SUP][/SIZE][SIZE=-1][SUB]97.1[/SUB] [SUP]71.6[/SUP][/SIZE][SIZE=-1][SUB]96.4[/SUB] [SUP]71.8[/SUP][/SIZE]
[SIZE=-1]85[/SIZE][SIZE=-1]91.8[/SIZE][SIZE=-1]95.4[/SIZE][SIZE=-1][SUB]110.0[/SUB] [SUP]85.6[/SUP][/SIZE][SIZE=-1][SUB]111[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]117.9[/SUB] [SUP]102.0[/SUP][/SIZE][SIZE=-1][SUB]116.4[/SUB] [SUP]91.6[/SUP][/SIZE][SIZE=-1][SUB]77.5[/SUB] [SUP]70.9[/SUP][/SIZE][SIZE=-1][SUB]105.7[/SUB] [SUP]79.0[/SUP][/SIZE][SIZE=-1][SUB]105.0[/SUB] [SUP]79.2[/SUP][/SIZE]
[SIZE=-1]90[/SIZE][SIZE=-1]99.8[/SIZE][SIZE=-1]104.4[/SIZE][SIZE=-1][SUB]119.5[/SUB] [SUP]93.8[/SUP][/SIZE][SIZE=-1][SUB]122[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]128.1[/SUB] [SUP]111.4[/SUP][/SIZE][SIZE=-1][SUB]126.3[/SUB] [SUP]100.4[/SUP][/SIZE][SIZE=-1][SUB]85.2[/SUB] [SUP]78.1[/SUP][/SIZE][SIZE=-1][SUB]114.8[/SUB] [SUP]86.8[/SUP][/SIZE][SIZE=-1][SUB]114.1[/SUB] [SUP]86.9[/SUP][/SIZE]
[SIZE=-1]95[/SIZE][SIZE=-1]108.3[/SIZE][SIZE=-1]114.1[/SIZE][SIZE=-1][SUB]129.4[/SUB] [SUP]102.5[/SUP][/SIZE][SIZE=-1][SUB]132[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]138.8[/SUB] [SUP]121.4[/SUP][/SIZE][SIZE=-1][SUB]136.8[/SUB] [SUP]109.7[/SUP][/SIZE][SIZE=-1][SUB]93.3[/SUB] [SUP]85.8[/SUP][/SIZE][SIZE=-1][SUB]124.5[/SUB] [SUP]95.1[/SUP][/SIZE][SIZE=-1][SUB]123.6[/SUB] [SUP]95.2[/SUP][/SIZE]
[SIZE=-1]100[/SIZE][SIZE=-1]117.2[/SIZE][SIZE=-1]124.3[/SIZE][SIZE=-1][SUB]139.9[/SUB] [SUP]111.8[/SUP][/SIZE][SIZE=-1][SUB]142[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]150.1[/SUB] [SUP]132.0[/SUP][/SIZE][SIZE=-1][SUB]147.8[/SUB] [SUP]119.6[/SUP][/SIZE][SIZE=-1][SUB]101.9[/SUB] [SUP]94.0[/SUP][/SIZE][SIZE=-1][SUB]134.6[/SUB] [SUP]103.9[/SUP][/SIZE][SIZE=-1][SUB]133.7[/SUB] [SUP]103.9[/SUP][/SIZE]
[SIZE=-1]105[/SIZE][SIZE=-1]126.6[/SIZE][SIZE=-1]135.1[/SIZE][SIZE=-1][SUB]150.9[/SUB] [SUP]121.6[/SUP][/SIZE][SIZE=-1][SUB]155[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]162.0[/SUB] [SUP]143.3[/SUP][/SIZE][SIZE=-1][SUB]159.4[/SUB] [SUP]130.1[/SUP][/SIZE][SIZE=-1][SUB]111.1[/SUB] [SUP]102.7[/SUP][/SIZE][SIZE=-1][SUB]145.3[/SUB] [SUP]113.2[/SUP][/SIZE][SIZE=-1][SUB]144.3[/SUB] [SUP]113.1[/SUP][/SIZE]
[SIZE=-1]110[/SIZE][SIZE=-1]136.4[/SIZE][SIZE=-1]146.5[/SIZE][SIZE=-1][SUB]162.5[/SUB] [SUP]132.0[/SUP][/SIZE][SIZE=-1][SUB]165[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]174.5[/SUB] [SUP]155.1[/SUP][/SIZE][SIZE=-1][SUB]171.6[/SUB] [SUP]141.1[/SUP][/SIZE][SIZE=-1][SUB]120.7[/SUB] [SUP]111.9[/SUP][/SIZE][SIZE=-1][SUB]156.5[/SUB] [SUP]123.0[/SUP][/SIZE][SIZE=-1][SUB]155.4[/SUB] [SUP]122.9[/SUP][/SIZE]
[SIZE=-1]115[/SIZE][SIZE=-1]145.8[/SIZE][SIZE=-1]158.6[/SIZE][SIZE=-1][SUB]174.6[/SUB] [SUP]142.9[/SUP][/SIZE][SIZE=-1][SUB]178[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]187.7[/SUB] [SUP]167.7[/SUP][/SIZE][SIZE=-1][SUB]184.4[/SUB] [SUP]152.8[/SUP][/SIZE][SIZE=-1][SUB]130.9[/SUB] [SUP]121.6[/SUP][/SIZE][SIZE=-1][SUB]168.3[/SUB] [SUP]133.5[/SUP][/SIZE][SIZE=-1][SUB]167.1[/SUB] [SUP]133.3[/SUP][/SIZE]
[SIZE=-1]120[/SIZE][SIZE=-1]157.7[/SIZE][SIZE=-1]171.3[/SIZE][SIZE=-1][SUB]187.4[/SUB] [SUP]154.5[/SUP][/SIZE][SIZE=-1][SUB]193[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]210.5[/SUB] [SUP]180.9[/SUP][/SIZE][SIZE=-1][SUB]197.9[/SUB] [SUP]165.2[/SUP][/SIZE][SIZE=-1][SUB]141.6[/SUB] [SUP]131.9[/SUP][/SIZE][SIZE=-1][SUB]180.6[/SUB] [SUP]144.5[/SUP][/SIZE][SIZE=-1][SUB]179.3[/SUB] [SUP]144.2[/SUP][/SIZE]
[SIZE=-1]125[/SIZE][SIZE=-1]169.1[/SIZE][SIZE=-1]184.7[/SIZE][SIZE=-1][SUB]200.7[/SUB] [SUP]166.7[/SUP][/SIZE][SIZE=-1][SUB]205[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]216.0[/SUB] [SUP]195.8[/SUP][/SIZE][SIZE=-1][SUB]212.0[/SUB] [SUP]178.2[/SUP][/SIZE][SIZE=-1][SUB]152.9[/SUB] [SUP]142.7[/SUP][/SIZE][SIZE=-1][SUB]193.6[/SUB] [SUP]156.1[/SUP][/SIZE][SIZE=-1][SUB]192.2[/SUB] [SUP]155.7[/SUP][/SIZE]
[SIZE=-1]130[/SIZE][SIZE=-1]181.0[/SIZE][SIZE=-1]196.9[/SIZE][SIZE=-1][SUB]214.7[/SUB] [SUP]179.5[/SUP][/SIZE][SIZE=-1][SUB]220[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1][SUB]231.3[/SUB] [SUP]209.5[/SUP][/SIZE][SIZE=-1][SUB]226.7[/SUB] [SUP]192.0[/SUP][/SIZE][SIZE=-1][SUB]164.8[/SUB] [SUP]154.1[/SUP][/SIZE][SIZE=-1][SUB]207.1[/SUB] [SUP]168.3[/SUP][/SIZE][SIZE=-1][SUB]205.6[/SUB] [SUP]167.9[/SUP][/SIZE]
[SIZE=-1]135[/SIZE][SIZE=-1]193.5[/SIZE][SIZE=-1]214.8[/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]238[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]242.2[/SUB] [SUP]206.5[/SUP][/SIZE][SIZE=-1][SUB]177.3[/SUB] [SUP]166.1[/SUP][/SIZE][SIZE=-1][SUB]221.3[/SUB] [SUP]181.2[/SUP][/SIZE][SIZE=-1][SUB]219.3[/SUB] [SUP]180.7[/SUP][/SIZE]
[SIZE=-1]140[/SIZE][SIZE=-1]206.6[/SIZE][SIZE=-1]229.4[/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]250[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]258.3[/SUB] [SUP]221.7[/SUP][/SIZE][SIZE=-1][SUB]190.4[/SUB] [SUP]178.8[/SUP][/SIZE][SIZE=-1][SUB]236.1[/SUB] [SUP]194.8[/SUP][/SIZE][SIZE=-1][SUB]234.4[/SUB] [SUP]194.1[/SUP][/SIZE]
[SIZE=-1]145[/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]271[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1] [/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]204.2[/SUB] [SUP]192.1[/SUP][/SIZE][SIZE=-1][SUB]251.5[/SUB] [SUP]209.1[/SUP][/SIZE][SIZE=-1] [/SIZE]
[SIZE=-1]150[/SIZE][SIZE=-1][/SIZE][SIZE=-1][/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]289[/SUB] [SUP]~[/SUP][/SIZE][SIZE=-1] [/SIZE][SIZE=-1] [/SIZE][SIZE=-1][SUB]218.7[/SUB] [SUP]206.1[/SUP][/SIZE][SIZE=-1][SUB]267.7[/SUB] [SUP]224.1[/SUP][/SIZE][SIZE=-1] [/SIZE]
Here is a P-T for basically R-12 and R-134a. Not the best chart, one I use won't even fit in here. At higher temperatures, R-12 increases at a linear rate, R-134a is more like exponential.
If the low side pressure is 95 psi, lowest vent temperature is 85"F plus any heat losses by the time it gets to the vents. This was very common with GM CCOT systems over like a 30 year period due to higher ambient temperatures increasing the low side pressures. With R-12 at 94*F ambient would be lucky to hit a low of 65 psi low side resulting around a 72*F vent temperature.
Best system was the POA in the early 60's with an A-6 compressor, POA would regulate the pressures to 28.5 psi, and plus it used a variable expansion valve to keep those low side pressures in check with even a 125*F ambient. So would get a vent temperature of 35*F after heat losses, warm enough so the evaporator would not freeze up.
Japanese used just the variable expansion valve to attempt to maintain low side pressures, but used a thermistor in the evaporator to kill the compressor if the temperature would drop below 33*F, would kick on again if the evaporator temperature hit 39*F. Was like the CCOT system, but the expansion valve greatly decreased cycling, CCOT system was either full blast on, or off, sure wore out clutches in a hurry and really a strain in single belt drive components.
V-5 used in the Cruze is a great improvement over the CCOT system, monitors the low side and varies the displacement of the compressor to attempt to maintain a near constant low side pressure, does not cycle and runs all the time when the AC switch is on. Only uses a high side thermistor that measures temperature, but implicitly replaces and old fashion pressure switch due to the P-T characteristic, in the range of an equivalent of about 45-420 psi.
If under charged, and if the high side is above 45 psi, the evaporator could freeze up, will noticed this quick when your vents quit blowing air. If over charged, will hit the 420 psi level, in particular at hot ambients, and the compressor should switch off, providing the thermistor is working properly. But also causes severe stress on the belt drive components including the water pump.
You can get lower ambient temperatures by overcharging the system, but risk blowing its cork at the higher ambient temperatures.
Well I'm still within factory service pressures provided by the book and its BONE CHILLING cold! So cold I never have to use 4 on the blower speed so I recommend this and thanx again OP!
Mine is still operating/ functioning great! Glad others have had similar experiences!
I'm thinking about doing this. Would your charts listed in the OP apply to both the 1.8L and the 1.4L Turbo?
21 - 26 of 26 Posts
