Go back to COMG- The Cruze Owner's Maintenance Guide
Here is a DIY on how to flush your brake fluid.What you will need:
1.) A container that can hold 24oz or more.
2.) 1/4" translucent tube (any major hardware store will have this) $3 for 10'
3.) 10 mm wrench
4.) 3 bottles of Dot 3 brake fluid (I used AMSOIL 500 series high performance synthetic brake fluid) you can get this from our forum AMSOIL dealer XtremeRevolution.
You do not need to take off the tires for this DIY. But the rear (drums in my case) is a little tight getting the wrench in the right angle.
You should flush your fluid after 2-3 years. Reason being is that brake fluid absorbs moisture. And after acouple years that water in the system causes the boiling point of the fluid to drop.Most new DOT3 fluid has a boiling point of 460-500* after 3 years the system will have around 3-5% of water contamination and reduces the boiling point to around 300*.
There is aprocedure on which tire to start with first. You want to start with the side farthest away from the reservior 1st makeing your way to the closest.
(there are many diffrent ways to do it. This is the most common one)
1.Rear passenger
2.Rear Driver side
3.Front Passenger
4.Front Driver side
Drill a 1/4" hole to fit the hose. Then you need to put 1 or 2 holes in for venting the pressure.
Push the tube to the very bottom of the bottle.
Locate the Brake fluid reservior.
-Rear Passenger side Drum-
Locate the bleeder and take off the dust cap.
Attach the tube. Note that you might need to warm up the end to fit it over the nipple.
Gravity will force the fluid out slowly so dont crack it open till the tube is on.
Also, it's a good time to note that the Brake fluid is like a paint thinner and bad for your skin and eyes, so be carful.
Use your 10mm wrench to open the bleeder.
Now pump the brake petal to lower the old fluid in the reservior, But DONT let it go too low. once its low enough top it off with your new fluid.
Keep doing this process untill you see new clean fluid coming through the tube.
-Front Calipers-
***Under Construction***
3.) 10 mm wrench
1.Rear passenger
2.Rear Driver side
3.Front Passenger
4.Front Driver side
-Front Calipers-
