1 - 20 of 25 Posts
Many of you have seen that GM was kind enough to leave the wiring behind in 2012 Cruzen so you can just plug-n-play a glovebox light.
All of this is explained in the HOW TO: Install A Glove Box Light in 2012 Cruze by silverram323.
Of course, GM being GM, the wiring was deleted on 2013 and subsequent Cruzen. :$#angry:
After subscribing to Alldata I was able to find the information needed to install AND wire a Glove Box Light in 2013 on Cruzen following the factory specifications in terms of what wires to tap and connector to use. Of course, GM being GM, made this little project tremendously more expensive than what it needs to be if you go with all "GM" parts.
For instance...
Glove Box Lamp: 13503057 $8.99, (eBay, free shipping) :th_dblthumb2:
PT2838 Cab Light Wire Connector OEM: 13580951 $61.25 (eBay, $3.17 shipping) :dizzy:
Since I had already bought the lamp, (before figuring out the connector number and cost of same), I decided to continue on my quest for the elusive shining beacon of glove box light.
With a little bit of digging, (and detective work of puzzling out the OEM nomenclature), I was able to find that the connector that GM is so proud of can be procured from their supplier, TE Connectivity, for a much more affordable price of $0.30. (Mouser Part Number 571-1563189-1; DESC: MT 2, REC HSG,CODA TE Connectivity Automotive Connectors)
No... That is not a misprint. The $61.25 OEM Connector from GM only costs THIRTY CENTS! :eek:mg:
The pins that you need for this connector are also a bit pricey at $0.22. You will need 2. (Mouser Part Number 571-964263-2; DESC: MICRO TIM2 CONTACT TE Connectivity Automotive Connectors)
If you do buy the pins be aware that you need the special AMP crimper to make sure and not screw them up. Regular crimpers are a pain in the a** and usually end up folding them into miniature pretzels. Since I am tool fanatic I went ahead and splurged and bought one of these on Amazon.
You could also try to find the correct connecter with a pigtail from some other source, (*cough VW cough*), but I didn't have the time nor the inclination to go figure out which ones I needed, (even though I do have ETKA electronics parts catalog), and the pigtail would probably be too short anyway so I just ordered what fit the connector according to Mouser.
So now on to the fun stuff.
I will not repeat the previous HOW TO in terms of the actual installation of the lamp. (besides to state that I really hate the soft, gummy plastic that GM uses for the glove box. Almost impossible to make a clean hole for the switch.)
Text Line Diagram Technical drawing Font
The alldata wiring diagrams are fuzzy at best but if you look at E27 Instrument Panel Compartment Light you can see that it pulls power from pin 2 of the X7 block connector of the K9 BCM.
Text Font Line Number Monochrome
Pin 2 is identified as Inadvertent Power Control with a White/Brown wire.
Diagram Auto part Line art Parallel
The X7 connector is shown here, (the pinout numbering is after you unplug the connector and look at it straight on), and to avoid aggravation I can tell you that it is the GREY plug in the last right position of the K9 BCM box.
Electronics Light Wire Technology Electrical wiring
After unplugging the X7 Connector and verifying that Pin 2 does have power I used a wire tap and peeled back the wire sheath to install the power wire, (doesn't matter which wire you use on the connector to the lamp but if you want to be pedantic Pin 1 is power and Pin 2 is Ground), I had already prepared and run from the Glove Box Light down to the BCM, (that is located behind the passenger side kick panel).
Once the power was connected I installed a ring terminal to the ground wire and installed it on an instrument panel bolt to complete the circuit.
Plug every thing back in to the BCM and.....
Light Automotive lighting Technology Headlamp Cable
Plug in the lamp.
Bob's you Uncle! :clap:
Awesome write up. I have never felt the need for a glove box light, but it's an easy, cheap mod, so I might consider it anyway.
Based on your wire diagram, it looks like Pin 2 on the X7 K9 BCM connector is also used for the passenger reading lamps. You could also tap into that wire at pin 6 on the X210 headliner harness connector, which is located a couple inches from the glove box on the right side just below the a-pillar. You can see the connector through a hole when the glove box is removed.
OP-
Thanks for sharing your info, specifically making the GM plug. Several years ago I was contributing to a thread where UpstateNY (I think that's his handle..) wanted to add heated mirrors to the Cruze. At that time he bought the wiring harness for the door, because the car didn't have pins in the connector for the heated mirror circuit.
While I've looked at Mouser before for electrical connectors, I've never worked with them. Nice to see an actual installation.
Reactions: Blasirl
OP-
Great thing about Mouser is that they have EVERYTHING electrical you will probably need. :)
Problem with Mouser is that they have EVERYTHING electrical you might need but YOU HAVE TO KNOW what it is to actually order it. :(
In this case the alldata connector view actually gave the trade name of the connector, (but not the manufacturer). A little detective work found that the trade name coincided with TE Connectivity. TE Connectivity has a very nice website that has pictures of each different connector, (including 3d images and the blueprint spec sheet), but you have to have an idea of what the connector looks like and then go through all of the permutations until you find the correct one. If I remember correctly the automotive connectors with 2 pins number something like 538 different connectors. Since I had an idea from the connector view what the connector looked like I was able to find the right one and then take the TE Connectivity part number over to Mouser and find the actual part.
I did a similar search to find the connectors for factory heated seats when I was considering doing my seats using factory components. Delphi connectors is another large GM connector that was used on older GM's. Since our cars are a globally sold car, I'm guessing there might be more global connectors rather than all Delphi.
I agree, the only way to find the correct connector, or pin for that matter is to find the connector manufacturers design information. I remember trying to think of how to crimp the pins. I never thought of a tool from Amazon..
It's a lot of work, but it's really cheap vs. buying the GM pigtails!
Thanks for the info. I just realized today that I have no glove box light on my 2018. Just got it last week. I'm lucky that the box has the cutouts for the light and plunger.
I ordered the plug, pins and light assembly. I'll end up tapping into the power port. My 2018 has the power port up front in the center console. Easy to get too. Again thanks for your research on the parts needed.
Doing the same here. Please take pics for us with Gen 2 models.
Sent from my SM-G965U using Tapatalk
· Administrator
Here is a video for glove box removal on a 2016. He has the light installed. It looks like OEM. Not sure which year or trim line the light was omitted. The power port was a good place to tap into unless you might be lucky to have a year that GM kept the harness and just tucked it away.
https://youtu.be/NkRMCLno3jk
That is a good video, but it is for a Gen II. This thread would be a better spot for it.
[h=1]Glove box light. Did any include it?[/h]
I know this is an older thread but was there a open slot on the X7 so I wouldnt have to pirate the power from Pin 2? I read that the 2012 had the connector there but no light, so im curious where it plugged into.
I have leftover female terminated leads from my MyLink project and I LOVE the OEM look, rather than splicing into the wire.
· Administrator
rather than????
Install complete. Super easy and worth the ~$20. Only thing I am going to add is a bezel around the button hole. I did a decent job at cleaning it up but since it's angled it's not that pretty. No one would ever know but I'm a stickler when it comes to stuff that doesn't look 100%. Off to Google to find a bezel.
· Administrator
So Pray Tell....What does it look like now?
· Administrator
Dang, just saw this. Here is a few pics. You cant even tell from sitting in the seat that the post for the switch isnt perfectly centered so all in all I think it was a huge success.
View attachment 269929 View attachment 269931
No idea why they are sideways and upside down..... Just clock your head and then it will look right lol
Not too late are we? Looks good.
I like how your Kleenex levitates though!
1 - 20 of 25 Posts
