Ok so I know there have been other post on this topic. I'm an Electrician and a back yard mechanic. I don't like the 12v outlet dead when you turn the car off. Here's my fix with no move or cutting of wires.
I was looking at the info from other on making the 12v outlet hot all the time. And here's the info there's two purple wires the go to the outlets and the blue and white stripe it's the hot side of the # 6 and 7 fuse. Those blue and white stripe wires go to a relay on the top of the fuse box.
Those are the back side of the fuse box that on the left inside under dash side of the car . Here is the front side of the fuse box
You have to push the two upper tabs in on the right and left side of the fuse box to remove the fuse box to get to the relays on the top if. It will hing down and then you can unhook the bottom of the fuse Bo's by lifting I all up and out of the dash.
The top right relay is the one the 12v power outlets are controlled by. These four wires to this relay two are a coil that closes when you turn on the car. The others is a hot all the power source and the blue and white stripe that goes to the fuse for the outlets.
Note see the blue and white wire and the red one behind it.
So the only thing you have to do is keep this relay closes all the time. I'm going to use a toothpicks to hold the relay closed. When you have the car running the coil will still be pulling in this relay as well. The toothpicks will hold the relay closed when the car is not running. Here this the relay and the cover removed from it.
There I have the red test probe at is where you will need something to hold the relay closed. As I said I will be using two toothpicks that I will put in the spot the test probe at an right next to it. With the relay now closed all the time reinstall it and the 12v power outlets now will stay hot all the time. This will do both the front and the back outlets. Hope this help people that want there outlets hot like I do and don't want to cut or move wires and the car.
