1 - 10 of 10 Posts
well driving around in auto mode today, had to come to some what complete stop at 10mph, after the car turned i went wot to get up to 65mph. and noticed a slight bang kinda noticeable but nothing that sounded major (no dtc's or lights) near 40mph area. not sure what gear maybe 2-3rd? not wanting to think its a trans problem due to car drives good, and is stock. but it was pretty smooth after that. but i never hit wot. maybe half throttle?
here is the thing i hardly drive in auto mode expect when people are with me, but other then that car stays in manual mode. i hit wot hitting close to redline before shifting each time. leaving my dads house, shifting the gears, car took it and ran with it. hitting 90mph she took it just fine no problems.
manual mode 97%
auto mode 3%
wot is wide open throttle by the way....
but do we have a limp home feature on the trans?
this isnt related but do we have a feature that will let us drive the car if something happens to the power steering box or if it goes out, we cant drive home?
thats probably why it did that? see i never noticed it in auto mode, if its in auto i drive easy 99% of the time. manual mode i choose my own shift points and down shift when needed.
makes me wonder several questions..
1. if i dont use auto mode that often does the car learn my last driving habits and uses them for when i switch to auto mode?
2. if i put it in auto mode to talk on the phone/ or what ever. i live in the hill country in texas where i have to drop to 5th gear to go up hill. what shifting does the car use, or does that matter. since the cruze is set?
see this is my first car that has more computer stuff then my 2 trucks did combined. my last truck the 96 ram. had a pcm, but it mostly controlled 4th gear and lockup. shifting was done via valve body working off throttle input or the tps harder i mashed the higher the shifts, could even adjust the shifts points some.
off topic but i found out that this thing loves 4th gear at 30mph 5th is on the edge of a downshift for me, lowest it stays in 5th is 28mph.
The Cruze has a limp mode that will allow you to drive a short distance on seriously reduced power. Also, if your power steering goes out you can still steer the car - it just becomes a very heavy rack & pinon steering feel. Also, the brakes will continue to operate normally until you get to low speed in this situation. At low speed you'll need the hand brake.
thank you that's good to know if the computer goes out (hope it never happens) i can limp it home. i drove that 89 (thing loved to eat pwr steering pumps and break belts) only way i could turn it easy was hit the gas and make the rear help me out some... not sure what setup it had. but it was a pain to steer.
i hate to de rail but, how are the brakes tied in with the steering.
i am surprised what i did didnt hurt my trans, ok when you get mad make sure you know what your doing so not going to detail of what caused it, but anyway i got upset (car was in park) threw it in drive and hit the gas hit 40mph and decided to shift and went into neutral, (couldnt move over and was on a busy highway with traffic coming behind me) so i slowed down to 20mph and went back to drive and went to manual mode and got back up to speed in a hurry. no grinding or codes (just smooth shifting)
if i remember right this car wont let you go from neutral to drive unless your at a safe speed. i can understand, if your below 5mph but 20mph hard to believe
also i found out at a stand still i can go from reverse to drive without the brake, drive to reverse need the brake pressed in..
I've done this on accident before. Thought I was in manual mode. Neutral to drive is safe as the computer rev matches. It won't let it go into drive at high rpm though. It blinks "D" until the revs drop to a rev matched point.
I mistakenly shifted from reverse to D while still rolling back at a few MPH(not enough brake action on my part in a speedy maneuver), the transmission did not engage D, it put it into neutral instead. On a rental cruze I put car in park while rolling at 5mph, same thing occurred.
Nice to know it will save itself from at least some stupidity.
To address your concerns, my trans has always had a crappy 2-3shift when at 4000-4200RPM. Above that RPM its smooth or below, but its almost always a bit abrupt/harsh at that RPM, only that gear though. With bumping it into neutral, nothing to worry about, just get off the gas to shift back into D. I like to use neutral on a few routes I drive(longer coasting) and just slide the lever back to D at whatever MPH I'm at. I have bumped neutral a few times, I just wait a few seconds for the RPM to settle down to shift back to D.
Discussion Starter · #10 ·
ya its a nice thing that this car does save its self from user error.
so far i havent noticed the issue yet. hopefully it was a one time thing.
1 - 10 of 10 Posts
