Published capacity is 13.7 gallons for the 2017 diesel. Interesting that you only got 13.7 in after running 65 miles past the low fuel light.
Sounds like 2017 may differ from the Gen 1 (2014-15) diesels.
Yesterday I finished a 1,000 mile tank on my 2014 diesel. Published capacity is 15.6 gallons, so nearly 2 more gallons than the 2017.
At initial fill up, I spent about 10 minutes topping off up to the end of the filler neck. Takes a lot of patience because diesel 'foams' a lot as it comes out of the pump.
I drove 92 miles after the Low Fuel light illuminated. Filled the tank to the end of the filler neck and took 18.511 gallons.
I figured the 'extra capacity' came from the 2 gallons of "reserve" after low fuel light plus another .9 or so in the filler neck.
So I would've expected your experience to be similar...gaining an extra couple of gallons beyond published capacity by running past low fuel light and filling to end of filler neck. Would be interested to hear from other 2017 diesel owners regarding 2017 fuel capacity.
