I've been trying to quit smoking (pack a day type of guy) and my buddy got me into vaping I have a sub ohm Istick 30 watt mod and I have to say it's working so far the e liquid I use is only 3 mg of nicotine and I'm down to 3 cigarettes a day, what set up is everyone else using
I've been vaping for about 5 years. Best switch I ever made. Started out with 24mg, and now I am only using 1mg. I may decide to just quit someday, but I still like it for now. I mix my own juice so I know there is nothing bad in it.
I use the eGO batteries. When I started I was using an old 510 atomizer. Those were a mess to use, but there weren't many other options. Because of the mess, I did direct dripping for a while. Later I switched to cartomizers. Now I am using a BDC tank. The tanks were a huge improvement on vaping.
You should increase your nicotine and make the complete switch to vaping. Use enough nicotine that you don't feel like you need a cigarette and it will make the switch easier. Then later you can reduce the nicotine slowly. But don't worry about reducing the nic until you have successfully made the switch.
I also personally believe you should use a standard battery and a standard atomizer. Don't use the low resistance atomizers or high voltage batteries. I say this because some research has shown that higher voltage and lower resistance causes the juice to burn more, which causes more toxic chemicals to form. I also suggest staying away from all of the flavorings for the same reason. I don't add any flavor to my juice, and I still love it.
I know I am quite late to comment but maybe it helps someone else, really vape help us to get rid of smoking, I also was doing smoking 1 packet per day, it was lil bit difficult to get rid of it, now I use vape occasionally, I mostly buy my stuff from ECig-City Coupons, because here varieties of flavors are available , it helps me to stay away from cigarette. I hope you will also quit smoking soon.
Hi buddy, I had a similar situation. I was forced to start smoking vape because cigarettes had a very negative effect on my health and the doctors even said that I could run with lung cancer and I decided that I urgently needed to do something. I told this to my friend and he said that vaping is a great idea and I decided to try it. He gave me a great vape for beginners for $ 300 and bought a premium vape liquid to interest me. To begin with, we added a little nicotine to the liquid so that the body could wean off nicotine and eventually I completely switched to vaping and forgot about nicotine addiction. I am very glad that I quit smoking cigarettes and that I changed my life. Thank you for listening to my story!
