Won't know till someone tries. Looks like they have a silencer in the zip tube as well.Hey I remember reading on the last gen cruze that the best mod for the 1.4l was removing something under the airbox? Some piping or something? Does that still apply to my 2016 Cruze? If so anyone know if it's the same process?
In my opinion the RS package should include all these from the factory. I never understood why they never produced a performance packaged Cruze.For your second gen Cruze, another option would be to wait for GM's engined Cruze air intake system due mid 2017, part number #84083963. Final testing on it is now underway, and in fact talked to several GM affiliated test drivers/engineers who said that the combo of that intake, the performance exhaust (PN #84152660 -- also scheduled for mid 2017 availability), and the suspension lowering kit (PN #84105410, available soon) made the car a hoot to drive, and so equipped, it handled the autocross/track really well.
Based on past GM pricing, the GM air box will many times the K&N drop in air filter, however, produce more HP than just the filter. Or, buy the K&N and if you want more mid next year, you could then upgrade to the GM air box intake system.
The RS package, since its introduction on the 1st gen Camaro, has always been an appearance package (excluding the one vehicle which did not follow the typical RS "formula", the Sonic RS).In my opinion the RS package should include all these from the factory. I never understood why they never produced a performance packaged Cruze.
It gets you snazzy wheels/tires on the Gen 2! Woo.The RS package, since its introduction on the 1st gen Camaro, has always been an appearance package (excluding the one vehicle which did not follow the typical RS "formula", the Sonic RS).
An SS model, on the other hand, should have existed on the 1st gen Cruze - it's really a shame it didn't. With the 2nd Gen Cruze being a lot lighter, I feel like now is the time, as you'd have an SS Cruze that is much closer to the weight of the Cobalt SS than the 1st gen Cruze ever was.
Well, sorta. The tires/wheels that you get with the RS Premier are MUCH more grippy (Michelin MXM4) than the regular 17's. Little more road noise/less ride comfort, though.so RS LTZ doesn't add any "performance" parts but the RS on the LT does.
Hydroshield.I just went and did what you said you did with the air box ( Cruze Hatchback ) and I totally saw the cone type filter. I was thinking on buying those nets for K&N filters ( sorry I don't know the real name of them ) and wrap the stock filter with it and then run her for like 5 miles and see if I noticed any issues. I also saw kinda like a return air hose that goes in the bottom part of the air box. Don't know what that's for.
Wrong. The PCM adjusts fuel trims according to the o2 sensor readings. The stock airbox does not allow for a clean and accurate reading across the MAF so they use a restrictive air filter to basically slow the air down enough to make it less turbulent across the MAF. The smoother the airflow across the MAF makes for a more accurate reading and less fuel trimming required by the o2 sensors.Unless GM drops a tune with it, 0HP/OTQ would be the accurate since gen 1 kills mods after it figures out you modded w/o a tune.
Your proof or restrictive air box in old and new gen is? Have you actually opened the air box of a GM vehicle and see the air straightener? Honeycomb in the 90 and H bars in the Cruze? Unless you have proof, you need to stop telling people an intake w/o a tune (2 gen is too new to test that just yet) on the Cruze is productive when we have years of people running slower 1/4 times because they did this w/o a tune.Wrong. The PCM adjusts fuel trims according to the o2 sensor readings. The stock airbox does not allow for a clean and accurate reading across the MAF so they use a restrictive air filter to basically slow the air down enough to make it less turbulent across the MAF. The smoother the airflow across the MAF makes for a more accurate reading and less fuel trimming required by the o2 sensors.
That's the case on most cars. A cold air intake generally will piss the computer off, causing a CEL. A couple people have had luck with CAIs on the Cruze Diesel, but others have run them for a short period of time, ended up with CELs and a car that ran like ****, and went back to stop. If it was a true benefit (without a tune), I, an engineer, would have installed one. If I get a tune, sure, I'd be okay taking advantage of slightly improved airflow, but I have no intention of installing it on the stock calibration.Your proof or restrictive air box in old and new gen is? Have you actually opened the air box of a GM vehicle and see the air straightener? Honeycomb in the 90 and H bars in the Cruze? Unless you have proof, you need to stop telling people an intake w/o a tune (2 gen is too new to test that just yet) on the Cruze is productive when we have years of people running slower 1/4 times because they did this w/o a tune.
I have my own 2017 Cruze. And I've tried to post pics of my air filter swap but for whatever reason it won't let me. I replaced the stock filter with an AEM dryflow filter and there's no air straightener before the maf. I don't need to show proof just because you don't know how these things work. It's a possibility that a SRI wouldn't improve peak hp but low-mid range improvements would most likely be there due to the quicker turbo spool time and less low speed air restriction in front of the compressor. All of this equates to torque moreso than horsepower under the curve.Your proof or restrictive air box in old and new gen is? Have you actually opened the air box of a GM vehicle and see the air straightener? Honeycomb in the 90 and H bars in the Cruze? Unless you have proof, you need to stop telling people an intake w/o a tune (2 gen is too new to test that just yet) on the Cruze is productive when we have years of people running slower 1/4 times because they did this w/o a tune.
