just because Parts says it has to be ordered, does not mean the Service Department doesn't have it on hand. Parts will tell you if they have it on hand for the customer to buy, not if they have it on hand for Dealer use.
If you are going to buy the oil, why take it to the dealer for the change at all? Just for the free labor?I actually called the dealer today to set up an oil change. I asked them if I could get synthetic instead of the AC Delco synthetic blend. I was told they have Mobil 1, and they have put it into two Cruze Diesels so far. Problem is that it isn't the correct oil. It needs to be Mobil 1 ESP for the low SAPs content. This is going to royally piss off people when the oil the dealer recommended clogs up their DPF. I'm going to purchase the oil myself and ensure the dealer puts it during the free maintenance. After that I will do it myself.
Pretty much only reason I been going to dealer with my own oil. They put in customer request box "Fill with customer supplied Mobil 1". I let them deal with it for the reason I already had a bottle of soap break open in the trunk, don't want that to happen with the used oil in transport to advanced to recycle it. Already had that fun clean up when I stuffed the EJ257 in the trunk up side down of another car. I ended up saing F the oem mat and replaced with a wal mart area rug.Here's my thing though, if we go to the dealer and the do the oil changes giving use service records and documentation stating they did the servicing... Wouldn't that then leave the liability on the dealership not us? If something were to go wrong due to the service or type of oil being used that would then be an issue tied back to them?
If the dealer does all the service in the specified intervals and the components fail, there should be no question as to warranty replacement for the 100K miles. It's probably going to be an expensive lesson years down the line when all the DPFs need to be replaced under warranty and the dealers eventuall realize "Oh, yeah, we should have been using this other oil".Here's my thing though, if we go to the dealer and the do the oil changes giving use service records and documentation stating they did the servicing... Wouldn't that then leave the liability on the dealership not us? If something were to go wrong due to the service or type of oil being used that would then be an issue tied back to them?
Every stealership is different, while they do run on the same guidelines, let's just say a lot of things can be done under the table. After all it is a business, and when there is money involved, they will want to keep every penny. If you want to make sure they use Dexos, take it to a private mechanic, or do it yourself, and that way you can sure it is done. I will never trust my dealership on anything unless it is on paper and i can hold them against that little paperI was at my dealer today and they have the Dexos2 oil on the top shelf completely separated from the Dexos1 oil on the bottom shelf.
Also the caps on the bottles are different colours.
Yeah, that makes sense. Hopefully they won't give you crap about supplying the oil yourself.Yes. If they're going to have it on the lift to rotate the tires and drain the fuel filter of water, might as well have them do it for free. Honestly, I'd rather not change it myself, but if I can't trust the dealer I will have to.
I think the concern is dealerships that use the wrong oil. Who covers any damages in this instance?Hello All,
As long as you use the oil that is recommended per the owners manual and have very good records of each oil change, there should be no issues for warranty.
Erica Tiffany
Chevrolet Customer Care
