1 - 3 of 3 Posts
Hi, i have a 2012 1.8 lts Chevy cruze with 20.000 miles. A don't live in USA live in Venezuela.
Since two months ago i have issues with the door lock system of my car.
Four times It stop working with not response to the control And the look boton in the Dashboard.
But the trunck Opens with the control And with the Boton over the id plate.
Two times this happens after washing my car.
It is weird because at the hours o after disconect the negative pole in the battery the problem disapeares.
Have anybody the same problem o any idea of what It happening?
Thank you.
I know your Cruze was manufactured in Korea so the Negative Battery Cable PI isn't applicable. However, I would check the battery cable and I would consider the battery to be suspect. You're in a hot, humid climate and we have discovered that the North American Cruze's factory battery only lasts only 3 years or so, regardless of miles in this type of climate.
Thank You , the battery of my car have 20 months i had to replace It in December 2014 , yes i live in a hot And humit wheather, so i am going to check It so the battery cable too.
I was worry thinking in the BCM damage!!!
1 - 3 of 3 Posts
