I have a 2014 Chevy Cruze and recently my door locks won’t engage. The fob will alarm/dis alarm, pop the trunk and remote start the car. The button inside does nothing. When I put the car in drive or reverse nothing. Anyone have any idea what would cause this? Also all fuses are fine.
Do you hear any sounds? There should be a module or relay that controls each side of the locking action.
Discussion Starter #3
there is no sound. Pure silence when pushing and button. I’ve checked all fuses and they are good. Also I’ve tried to locate a relay and can’t seem too.
Look at the post by ChevyMgr at the end of this thread:
If her key is in the ignition then it shouldn't matter, believe the relay module may be to blame. Does it make a sound when you try to unlock.
Discussion Starter #6
the small door on my ignition closes so that’s not my issue either. No sound when trying to lock or unlock. Sometimes u may hear the electrical current go thru whatever but no sound of moving the locks up or down. It’s usually pure silent
