does anyone know the wiring diagram for the door open sensor wire. im trying to put curtasey lights in and need to wire them into that sensor wire. any clue?
I can check this in a few weeks cause I am doing the same thing but this is your circuit. Use a 2N2222 NPN transistor. This should allow you to run enough current for a few LED strips. 1 amp max I believe. Let me know if you have questions.
I should add, you can get more current by having that transistor trigger a relay instead or straight to the LEDs.
Another option would be to use a PNP transistor with the door trigger wire which will always work whereas the dome light will only work if you have the dome light turned on. This also means if you are cruzing and turn the dome light on your under dash will turn on too..
