Today is a day I shouldn't have woke up. I woke up to a backed up septic line. A company should be here for that tomorrow.
Later on today I got in my 2014 Cruze diesel with just under 79k on it to go to work tonight. I haven't driven the car alot but my girlfriend has me turned it's been doing the countdown to reduced power I've dealt with before. Last time it was for the ad def heater recall. When that occured I bought a cheap scanner off Amazon to find out what the codes were and it would also allow me to clear them-up until a point.
Well today it's the same deal. Clearing doesn't work. The car also died on me after startup but I figure that might have something to do with trying to clear codes with the engine running since it started fine after and I made it to work. The codes are the following-
P242D Exhaust gas temp sensor circuit high Bank 1.
P2428
P2047
P20BD
There were also some messages mentioning Sensor 3. After watching the video I posted below can someone tell me which of those sensors is number 3?
I'm hoping this is just some form of failed sensor that is easy and relatively easy to get to to replace but I've popped it in on the search and haven't found that exact code to narrow it down. Can someone help me out here? The car is Trifecta tuned if that amounts to anything.
It's infuriating that every issue with these cars has been with the exhaust system. The guy I bought it from had one recall done that I think was the block heater or some wire running to the engine related to emissions. The heating element failure happened to me about a year ago. And now here we are with more likely emissions related issues.
P2428
P2047
P20BD
