DrGubi’s Build
4905 Views 29 Replies 4 Participants Last post by  drgubi
7
DrGubi’s Build
Figured I’d make one of these since I intend on modifying the car a good deal in coming months (I’m having fun now before I start a new job). A couple months ago I knew virtually nothing about how an automotive works or how to modify it/the effects of doing so. I think you can all agree knowing how to maintain and modify an automotive is an incredible skill. So I basically set out to teach myself via YouTube, CruzeTalk, and straight up trial and error (that’s the BEST one). Here I’ll post my updates and any pitfalls I encountered along the way. Any recommendations and input are always appreciated! Also if you have any questions about certain modifications feel free to ask!
Current Car Info: 2012 LT Crystal Red 1.4L Turbo w/ approx 81K miles
Modifications in Order of Date Performed (those without pics will get them soon):
Motor trend floor mats
Maxracing Short Aluminum Antenna
Pioneer MVH-1400NEX Stereo w/ CarPlay
AEM SRI
Repaired/replaced trunk latch
ACDelco Iridium Spark Plugs
ACDelco Ignition Coil
Plasti-Dipped Front and Rear Emblem
Touched up hundreds of chips, scratches, rusting at the bare metal level (WHY is this thing a magnet for rocks????)
Spyder Projector Headlight Installed
Spec-D DRL LED foglight Installed
Plasti Dipped Wheels Gloss Black
Painted Brake Calipers Red
De-rusted front rotors and rear drum brake housing
Cougar Motor LED low beams
Magnaflow catback exhaust 15070
BNR 93 octane tune
PCV fix kit V2
Replaced throttle body gasket
Replaced valve cover and gasket
In Progress Modifications:
Planned Modifications/Repairs (in order of when they’re happening)
18” rims with new tires
Transmission fluid change @ 100K
LED hi beams
LED front turn signal lights
Spyder LED taillights
Blend mount for radar detector
Black side marker covers
Install backup camera
Install coilovers
Larger fuel injectors
BNR WGA
BNR GTX250 Turbo (only once/if mine bites the dust)
Land vehicle Vehicle Chevrolet cruze Car Chevrolet
Land vehicle Car Tire Vehicle Automotive tire
Land vehicle Vehicle Car Chevrolet cruze Grille
Headlamp Automotive lighting Light Vehicle Bumper
1 - 20 of 30 Posts
Nice start. What year?
First suggestion - install a Blend Mount or something similar to hang your detector from the rearview mirror. Makes it much more inconspicuous and gives the antenna a better view at the same time. Just run a wire up from the fuse block along the pillar garnish and to the center of the headliner along the windshield. Almost no removal of parts is necessary. If you have the dimming mirror, you have access to switched power right at the mirror and can use mirror taps. Because it is an LT though I assume you do not. Mirror tap also makes a generic kit to run from the fuse panel if you prefer.
It’s a 2012! Updated my original post. And that’s actually an awesome idea. I despise messy wires I can’t hide somewhere. Thanks!
One of the first things I did myself.
Looks good! How is the CarPlay integration? Do steering wheel controls and such all work?
The CarPlay integration is excellent, I don’t know how I existed without it! The steering wheel controls fully work and are actually customizable thanks to the Maestro RR module I installed alongside the stereo. It even came with an OBDII adapter that I routed under the steering wheel which lets the stereo display any readable value in the form of some nifty gauges (it can even read some CEL codes)
Plasti-dipped the wheels today and painted the calipers. Very satisfied with the results.
I like the look. To further your color scheme, consider these:
Well that’s getting bought. Going to Thailand for two weeks so will install headlights, fog lights, and those babies when I return (if only I could bring the Cruze :’( )
Finally installed the headlights and fog lights. I just need to find an evening that it’s NOT downpouring so I can align the headlight beams. Side markers will be in the future I’m dead atm.
What do you think of the Spyders so far?
I’m very happy with them so far. Build quality is solid, they feel like OEM. Installation was difficult but better than what I expected (tapped into sidemarker light wire). Road illumination is at least what I experienced with stock, if not slightly better. Only complaint is they make adjusting the headlights very difficult with the placement of the adjustment knobs. You’ll need a small child to reach them lol.
Now that I finally have some energy, I can clarify and provide an update. The headlight assemblies I installed were one of the Spyders available for the cruze and the fog lights are Spec-D DRLs. The installation was difficult as there was no specified direction as to what each of the arbitrarily colored and located wires on the back of the unit did. So I just took the pairs of wires and touched them to the according battery terminal to see what lit up.
For the actual wiring process, I cheated a little due to the odd geography of attempting to wire both headlights and foglight DRLs simultaneously. I took the cord from an old Nokia phone charger (ensuring it could handle the amps), spliced it into the sidemarker lamp wire, ran that up to just behind each headlight assembly, and then spliced all DRLs into said phone charger wire. Trust me it makes sense with this weird setup.
okay finally an update! I installed Cougar Motors LED headlight bulbs into the Spyder’s projector housing. They take an H7 bulb. The pair cost me $40, fit like a charm, look fantastic, feel fantastic, and perform swimmingly. I would strongly recommend this company for this price and quality. Like wow. Pics provided.
Magnaflow exhaust and BNR tune arriving shortly. Bank account crying. But my face is smiling so lol. Black Sky Water Light Night
Headlamp Automotive lighting Light Vehicle Car
Just ordered the PCV fix kit V2. There is a 110% chance I’m going to mess something up. But as Bilbo Baggins said... Natural landscape Font Adventure game Grass Tree
Just ordered the PCV fix kit V2. There is a 110% chance I’m going to mess something up. But as Bilbo Baggins said... View attachment 271379
My only advice, don’t break the plastic nipple when removing vacuum line. Cost me $50 for a new boost controller. (I think that’s what it’s called)
The Magnaflow exhaust (15070) is in! Installation was again met with many unforeseen hardships.
Automotive exhaust Auto part
First the original exhaust was so rusted in place, to remove it from the catalytic converter required penetrating oil PLUS sawzall-ing the darn rusted bolts off. Next, magnaflow saw fit to not include nuts for their bolts (I guess they assumed I was going to use my heavily rusted bolts I just sawzall-ed off?). Then it began to downpour like Malaysia in the rainy season.
Next, and this is what I could use some input on: the magnaflow exhaust hung lower and was looser under the car than the stock exhaust. I blame worn/too lax rubber exhaust hangers, but I didn't have time to run out and go trial a bunch to find a more rigid/tighter set of hangers. So I just stuffed a bunch of heat resistant insulation (pics) between the exhaust and the body of the car to hold it firmly in place (don't worry I tested with a blowtorch to confirm this stuff does not catch fire).
Tire Auto part Vehicle Bumper Automotive tire
Lastly, the exhaust tip was directly contacting the fiberglass body so I had to utilize a dremel built in 1942 to cut an additional 1/2 inch of space around the tip... I screwed up many times. I will be purchasing a new dremel and likely cutting off an additional 1/4 inch to make it look a little nicer.
Otherwise the installation was a piece of cake usual exhaust install. Had to cut the stock system up to remove it of course.
Auto part Wheel Automotive wheel system Tire Rim
Muffler Exhaust system Auto part Automotive exhaust
Overall, I am so satisfied with the results. This is exactly what I was looking for. It makes a big mean growl when it starts up and then quiets down to a deep hum. It produces additional deep growls when accelerating around 1500-2500 RPM but at highway speeds it's satisfyingly quiet. It even gives a nice growl when you turn the ignition off. The exhaust system from a quality standpoint felt excellent, and the tip looks great! Sorry I forgot to take pics of the system other than the tip, I'll add some more later.
I like how you flipped it over to take that pic. Must have been the cookie monster judging by the tip lip.
Lol idk why my computer uploaded the pic sideways. I’m just gonna use Tapatalk from now on. So much better.
BNR tune came at last! The difference it made was remarkable. The vehicle feels so much more nimble and responsive at lower RPMs. At higher RPMs (5000+) instead of a slow crawl upwards in speed, it steadily chugs through.
I’ve gone full throttle plenty of times before this tune. I take my foot off the gas at roughly the same time and end up in the high 60mph to low 70mph range. I did the same thing today (perhaps I was overzealous) and ended up at 94. Then my radar detector alerted me there was an officer in the area and I promptly wore out my brakes. Yay.
9
Been a while since an update, here’s what’s gone down:
Used BNR autocal to look at my LTFTs. Turns out they ranged between -9 and -16, indicating a likely boost leak. Hissing was audible near the throttle body at idle. Throttle body removed and cleaned and new gasket installed. Hissing persisted.
Auto part Engine Automotive engine part Carburetor Vehicle
Auto part Carburetor Automotive engine part Engine
Wire Tire Spoke Rim Circle
I had a PCV fix kit v2 I was waiting to install, so I promptly (and painstakingly) removed my intake manifold, installed the kit, and simultaneously ordered a boost leak test kit.
Auto part
LTFTs improved slightly, coming to -12 at their worst. Boost leak test kit came in, system pressurized to 22 PSI producing a profound leak from the front of the valve cover just beneath the oil dipstick, as well as near the throttle body. Valve cover and gasket were both replaced with observable damage to old valve cover in the area of the leak below (valve train doesn’t look bad for 83K miles?).
Motor vehicle Auto part Vehicle Car Engine
Engine Auto part Vehicle Automotive engine part Car
LTFTs dropped to an all time low and spend the majority of their time around -2 to -4, but I have seen them as low as -9 rarely. I have yet to pressurize the system again as I had to catch a flight to Miami, but overall the vehicle seems to feel more stable and responsive.
IN OTHER NEWS: while I was investigating my PCV fix, I noticed my inlet hose was leaking very slowly at the junction to the water outlet.
Engine Auto part Vehicle Car Fuel line
Upon further investigation, the head had broken off and adhered to the inside of the water outlet.
Auto part Engine Fuel line Vehicle Auto mechanic
I scraped out the broken pieces of the head and replaced the hose, but I still need to replace the water outlet. It’s sitting on my dining room table and will be completed post-Miami.
In OTHER OTHER NEWS:
My tires have a modest amount of dry rot and are nearing the end of their tread life, so they need replacing soon. Figured I’d upgrade the rim while I’m at it. Thinking about upgrading to 18x8 40mm offset gloss black Helos with a 225/45 set of directional tires. Alloy wheel Rim Wheel Spoke Auto part
So things have been pretty busy lol.
1 - 20 of 30 Posts
