Another update:
DUAL FRONT/REAR MIRROR DASH CAM & BACK-UP CAMERA
Was shopping around for a good dash camera. At first I was just looking at front-facing windshield-mounted units. However, I live in New Jersey, so the threat of getting rear-ended is very, very real - and if that day ever comes, I want video evidence of the jerk who does it, so in came the dual dash camera idea. Next, I figured if I'm going through the trouble of installing this camera, I might as well make it look good, so I opted for the mirror variety. In comes this one from amazon:
Buy TOGUARD Backup Camera 7" Mirror Dash Cam Touch Screen 1080P Rearview Front and Rear Dual Lens with Waterproof Reversing Camera: In-Mirror Video - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
It had the most reviews, the best reviews, was very detailed, and oddly enough was not bad at all on price. So I got it. Installation of the mirror (and front facing dash camera) was simple, just strapped it on to my mirror. Routed the power cable up under the headliner using conveniently supplied adhesive clips, into the A-pillar (had to remove that, it just comes out with some muscle, under the trim along the driver side, and into the rear cigarette lighter.
The camera wire took a similar path, but instead of veering into the rear passenger compartment, I kept it under the trim all the way to the trunk. Hooked it to some metal pieces in the trunk. Then took off the trunk liner. Now for the tricky part: how the hell was I to get the boxy camera (roughly 1x1cm) to the outside of the vehicle? I couldn't cut a **** hole that large, I only wanted a hole large enough to fit the cord which was approximately 3mm in diameter. Given that the camera did not conveniently remove itself from the wiring, I had to snip the camera off, route the wire stump through a hole I drilled in the trunk, and then solder the 5 individual sub-cables back to the camera, with each cable being about 0.2mm in diameter. This was very annoying, but I did that. Wrapped each individual cable in electrical tape, then wrapped the whole thing in electrical tape, tested the camera, and it worked! Next I routed the cable along the wiring on the driver side of the trunk, and it worked like a charm. Drilled two small holes to suspend the camera, and screwed it in. They conveniently provide a gasket and screws to hold the camera.
Lastly, the back up camera can automatically turn on if it detects the vehicle is in reverse via connecting to the back-up light positive cable. So I removed my driver-side headlight and routed the necessary wire behind the liner and spliced it into the positive cable. Now it is fully functional and I am exceedingly satisfied with it! Pics below.
TRUNK SPOILER
Next I picked up this subtle but very stylish spoiler from CruzeCulture:
https://www.cruzeculture.com/collec...vrolet-cruze-spoilerking-trunk-spoiler-284p-c
First, I placed the spoiler on and ensured its fit (which was perfect, albeit with some bending). I marked where it should go with some masking tape. I cleaned the mounting area thoroughly with 91% isopropyl alcohol. Next, I prepped the area with the packaged adhesive prep and a microfiber cloth. Then I took a heat gun to the spoiler to make it nice and pliable. The next step I feel is crucial and not listed in the guide (but I learned it from youtube).
There is very strong 3M adhesive tape on the bottom of the spoiler, covered by a thin red film you remove to install. I peeled back 1-2 cm of this film to expose the adhesive, and then taped the film to an accessible portion of the spoiler.
I placed the spoiler, using the 1-2 cm of exposed film to get a preliminary fit on the trunk. I maneuvered it into place very carefully and applied pressure.
Then I used the accessible pieces of film to pull off the remaining 2-3 feet of film, exposing the rest of the adhesive.
This resulted in me not having to move/reposition the spoiler and not screw up my fitment. The film came off and I applied firm pressure across the spoiler. I then thoroughly secured it with masking tape in several locations (see pic). We'll see how she looks in the AM (needs to cure for 24-48 hours).
