I have a 2015 Chevy Cruze LT 1.4 Turbo. I Recently had to change the window regulator and after reconnected the negative battery cable are reprogramming the windows, the window goes down but when going up the window goes up about 3 inches then stops. When you grab the top of the glass to try to help the window to roll up it wants to go down do its like playing tug of war with the window. The only time the window goes up and down by itself is when your reprogramming the windows after the cable is reconnected or when you unplug the wiring harness from the window regulator motor then plug it in again. This is the only time the window goes up and down on its own. Someone told me that there is a sensor for the window. Is there truth to that and where would the sensor be located
