1 - 4 of 4 Posts
What would happen if I got a E85 tune from trifecta(already have the advantage tune) for my car and left the stock injectors on? I'm not even looking to womp on it and get max power. More so just because it's 1 dollar or more less than premium at most place around where I live.
Would I be able to get a dialed back tune or anything from Trifecta, that would enable me to use E85 on stock injectors?
Thoughts below please :D
I've heard rumors on here the 2011 can get away with this, but I'm not sure how they are overcoming physics. The proper air fuel ratio needs to be maintained and the oxygenated fuel needs more fuel than the stock injectors can handle.
Basically you would be running lean and over time would damage your engine.
You well go lean and also be at Max DS on the stock injectors even on the 2011s
Reactions: spacedout
Meth is by far the best way to go.Stock injectors and great drivability.As long is the tune is expertly done and a fail safe added for if you run out your all set.
1 - 4 of 4 Posts
