Would u care to expand on the reason for the no?
So where does the vin reside?its vin specific
the ecm will have its vin, you have to program it for the new vinSo where does the vin reside?
I was assuming the ecm with the delete wouldn't know which car it was in.the ecm will have its vin, you have to program it for the new vin
thats reason 1 why its not plug and play
reason 2, is the delete tune locked to the original vin? if so, cant be used with new vin (your undeleted motor)
i wonder if the dpfs are programmed to the ecm for those not wanting to delete, on our western stars at work in 2015, the dpf/scr were programmed to the computer, couldnt just swap em over
VIN, Enviorment ID, and BCM/ECM exchange have to match up. Otherwise you’ll get a no start.Would u care to expand on the reason for the no?
Sooo sounds like it might also require all the bcms to work.🤔VIN, Enviorment ID, and BCM/ECM exchange have to match up. Otherwise you’ll get a no start.
I don’t believe there is anything really stopping the ECM from learning new ones. But no program exists to do it. GM SPS will not let you do it unless it’s a brand new ECM.
A JTAG program could do those things but why even bother with the used ECM then?
It’s been like this for a while. Any used GM ECU you find on eBay after about MY2012 are bricks.
Pretty much. It was a lazy way to prevent hot swapping modules to prevent theft.Sooo sounds like it might also require all the bcms to work.🤔
I figure it is also a way to make money.Pretty much. It was a lazy way to prevent hot swapping modules to prevent theft.
In reality it doesn’t *** work. How do you think trucks are being stolen? There’s nothing secure about this system. It exists only to make e waste.
Pretty much all newer GM vehicles have the PSCM in the steering gearbox.I figure it is also a way to make money.
I mean it sucks that if i have to replace my fuel pump control module it has to be "programmed" for my truck. Straight up BS.
Nope. 😜Can you do a manual VATS relearn on a Cruze? Can you change the VIN in modules using Tech2/MDI in the Cruze?
Only way to find out if the tune is locked is to buy the ECM and try editing it.
SPS. Now on Techline Connect.So let's say I need a new ecm. How do I put the cars vin in the new ecm?
