anyhow, make sure that you installed the wire harness in the correct slot.
see image below as to where the wire is supposed to go indicated by the red arrow.
All I have is this picture of where the terminal goes into the fuse box. If memory is correct the relay is already there. The factory service manual has the wiring diagrams. You can get 3 day access for $20 at: https://www.acdelcotds.com/subscriptions#
Hello everyone I have a 2014 Cruze with a usb and aux port in my center console. When I plug my phone in to the usb it does not charge my phone. I have tried many cords and also different phones and still no luck. It does not charge my phone. What could be the issue with it?
I have had some people ask me about reprogramming the VIN number in the radio, so I thought I would write a how to guide that explains how to disassemble the radio so that the chip can be reprogrammed.
For more information on upgrading to My Link, see this thread...
Go back to COMG- The Cruze Owner's Maintenance Guide
DIY Bluetooth A2DP (Bluetooth Audio Streaming)
So after reading and doing some research I've been itching on the idea of having factory Stereo Bluetooth aka A2DP. In the forum post on this site...
This installation guide applies to both the 1.4L turbo and 1.8L engines available in the Cruze. The 1.4T is covered first, followed by a slight variation that is found with 1.8L installation (thanks to Smurfenstein for the 1.8 info/pictures!)
This simple how-to illustrates how to install...
Hi,
I recently repaired my middle brake light myself after finding too high a price from wrecking yards and the dealership. Costing me about AU$15-20 (US$10-15) to do. No soldering required. More efficient than stock middle brake light - milliamp current draw reduced by at least 85%.
Items:
12...
