Eco Cruze Fog Light Install--Warning: Lots of pics!!
250280 222
Go back to COMG- The Cruze Owner's Maintenance Guide
I wanted to properly document how I did the installation of fog lights on my Cruze. Please understand that this is NOT a "how to" thread, and if you decide to follow these steps you are doing so at your own risk. By that I mean you risk voiding your warranty, you risk your safety and that of your vehicle.
The tools I used included at phillips head screw driver, a small flat head screw driver, a 10mm socket, rachet, extension, a T-20 torx, a small fork (you'll see), needle nose pliers,
Anyways on to the pictures.
This is what comes in the box from the dealer. I paid $200 for the kit. It comes with worthless instructions, the replacement insert panels, zip ties, new wiring harness, new switch and lights:
The first thing I did was to remove the negative pole off the battery. I would not want to be zapped or damage any components.
Next I undid the top fasteners for the front end. I know some folks have talked about doing it from the bottom, but I was ok with taking the nose off the car.
Using a small flat head screw driver, I was very careful to pull on the tabs.
Next I undid the 3 torx screws on either fender.
Then it was on to the bottom of the car. This is where the fork came in handy as these tabs did not want to move easily and I did not want to damage them.
Next I chose to deviate from the instructions and leave the flapper attached to the car. I saw no sense in taking the whole thing off.
This next part was the most difficult as the nose of the car is clipped on the the fenders. It was not easy getting it out, but with patience and a lot of care this finally came loose.
After unhooking all the wiring to the side lights, the temp sensor and to flapper motor (I wish I would had a helper for this); finally, the front end came off the car.
Next it was time to take off the factory inserts. I used the phillips head screw driver to do the job.
After removing the inserts from the factory, I inserted the ones from the kit, and screwed them in with the screws that were on the car.
I then next installed the fog light assembly that came in the kit after removing all protective coverings. I used the screws that came in the kit with the fog lights. There was no drilling necessary.
The last thing was to remove the temp sensor from the old panels and move it to the new ones. I was extremely careful as the tabs are very fragile!
This is how the nose of the car looked after having all the bits installed.
I then moved on to do the electrical connections by accessing this box on the driver's side of the car.
I was very careful on only loosen up these 3 bolts with the 10mm socket and rachet.
Once the screws were loose, I used a small, long flat head screw driver to pry the panel off the harness holder.
Once the panel was off, I focused on the harness at hand.
I removed the harness, flipped it over and after reading the worthless instructions, I inserted the wire where it belonged. I did this by using a pair of needle nose pliers to guide it in, then finished with a very small flat head screw driver to push it all the way in.
I knew the wire was all the way in by seeing that there was not metal exposed on the connector.
Next I routed the harness around the radiator and under headlights to get the wires where they needed to be. I also secured the ground wire to the nut on the front of the vehicle. I used the zip ties provided in the kit to make it all nice and neat.
Here's the pax side of the car all done.
Here's the driver's side all done and ready for the front clip.
I then installed the front clip in the reverse of the removal, playing close attention not to scratch anything. I then moved on to the fog light switch in the cabin.
The instructions told me to remove all these panels etc. But he only thing I had to do was to remove the fuse panel cover and gently push from behind.
It came right out. I had to be careful to push back the red tab in order to remove the connector. There are different color tabs in all the connectors, I just had to remember to push them back before trying to remove the connectors.
And finally got the new switch in.
Here's is a couple of pictures of the finished product. As you can see, the car has also had it's windows tinted. The whole job took me about 2 hours by myself (including the time to stop to take all these pictures). Had I had a second hand, it could have been done in less than an hour.
I think it gives the car a much better look. Anyways, hope you all enjoyed.
41 - 60 of 223 Posts
I just completed this project myself. Took about two hours and I did it from underneath (car was on ramps). Hardest part was accessing the top screw on the fogs but otherwise, straight forward install and looks great. Really makes a difference in appearance. I have to agree that those instructions sucked but were helpful to a degree. I referenced this walkthrough a few times before doing it and therefore didn't really need the instructions much :)
Thanks for this info. I'm completing the purchase of a new eco at this time and going to have them do the install. Great job BTW.
Ah...Maybe not. Didn't realize the injen also called for the front end to come off. The dealership was crazy on the install price as someone posted. You got me wondering though. Chevy loves to shut down the fogs when your high beams are on. This drives me nuts as it's when you need your fogs the most. Do yours shut down when going high? If so I'm going to mod.
My dealer installed the fogs for 1.5 hours labor, and did NOT have to pull the front end or re-program. They went underneath the front bumper, but did have the car on a lift, which makes it much easier.
High beams shut down fogs...
People driving with their fog lights on drive me nuts... because they use them as extra headlights, which they don't work for.
If you have your high beams on you are trying to light up down the road for some reason... if you are using your fogs you are trying to get light low and close (under the fog).
The two types of lights DO NOT work together to provide you any benefit, which is why GM shuts the fogs off when the high beams are on. I'd like to shoot out the fog lights on all the dumb SUV's I see around here running around with their fogs on all the time.
Please don't rig your car to have both high beams and fogs on.
I saw them on the GM website.
But on the list that lists what the kit includes it states:
"Programming Required (Not included in the price of kit)"
What exactly is this? Do you have to buy this seperately since it says its required?
Bought on ebay for $195 and installed from bottom of car with ramps in just over 2 hrs. No need at all to take off bumper. Now that I know what I'm doing I would see no problem in completing this project in about an hour. No programming is required!
How much easier is it when you take the bumper off? My friend has a pretty good ramp probably about a little less than a foot high. Is it truly worth taking the bumper off or is it non-aggravating enough to install without taking the bumper off. Im a patient worker and have done long projects over 4 hours before.
The bumper comes off in 15 minutes, and back on in 10. I'll be taking it off to install my foglights.
Reactions: RAY123
This is the part number on the kit I have right in front of me:
95469569
The kit comes complete with everything needed.
I'd highly recommend spending the $10 for Xpel headlight protection film. Two 4"x4" squares of clear or yellow film will protect the foglights from road debris and hazing over. Considering the kit is $200, it's worth an extra $10 to me to protect the foglights.
Hmm I might look into buying the kit and doing this. I have the black plates at the moment and they don't look too good.
Replacing the bulbs needs some ramps and to take off the lower splash shielding underneath the bumper. The assembly is screwed in from the back, so it's impossible to replace from the front.
Reactions: RAY123
