It's an artificial shut off limit.
Don't flood the charcoal canister and you'll be fine.
Hold on what do you mean? My old 12' Cruze even at E would never take more than 13 gallons because of a false limit? That means even though the needle is at the full marker it could take another 2 Gallons?It's an artificial shut off limit.
Yep. I've put up to 16.1 gallons into my ECO MT.Hold on what do you mean? My old 12' Cruze even at E would never take more than 13 gallons because of a false limit? That means even though the needle is at the full marker it could take another 2 Gallons?
Crazy! I will see how much my 16 can take next time I fill up. I'll be that guy *click* *click* *click*Dunno about the new Cruze.
The Eco is artificially limited to 12.6 gallons when it's still a 15.6 gallon tank that all the other Cruzes use. It saves weight for that extra 1 MPG city.
The most I've put in my Cruze LT with a 15.6 gallon tank was 13.9. Range was on "low" for some time. 13 is pretty normal close to "E".
I actually tried that just once, and nearly overflowed the new one.Crazy! I will see how much my 16 can take next time I fill up. I'll be that guy *click* *click* *click*
I don't know how much cooling that would provide, I suspect the reserve capacity is more so designed to protect the pump. My Gen 1 1LT had the 15.6 gallon tank(no restriction), On more than one occasion I had the low fuel warning com on right as I was pulling up to a pump. Every time it was 13.1gallons fuel burned, that leaves 2.5 gallon reserve at low fuel warning.I'm much of believer that running a tank empty is necessarily bad on fuel pumps. Especially newer vehicles. Safeguards have been implemented to protect pumps from overheating, such as the foam sleeve they put on modern pumps. They ensure that the pump has constant cooling no matter how much fuel is in the tank.
What does it do exactly?The pump actually sits in a plastic bucket which is full of fuel. I'm sure it stays cool even when very low on fuel. I believe the Cruze has about a gallon of fuel left when the range goes to zero. The FLVV is shorter on the regular Cruze than the Eco manual. There are FLVV's on eBay that're about 1/2" shorter than the 15.6 FLVV, and they are less than $20 delivered. I just installed one in my '13 Eco. I only have on fill up on it, but so far, so good.
