41 - 60 of 91 Posts
Discussion Starter · #50 ·
Ported manifold and installed pcv kit. Slapped a ported throttle body on there too...hopefully it wakes it up a bit. Waiting on new gaskets to install it all.
Picked up an SS sedan steering wheel with paddle shifters...got that wired up and installed
Discussion Starter · #52 ·
Hey nice power and sound build. Do you mind if I ask where you got the spacers and is there any chatter on hard accel or heavy braking?
Thanks! I got them on ebay, item # 192183963860. So far I've put about 300 miles on them and no noises or any issues. They're hub and wheel centric so they dont cause any vibrations either
· Administrator
Did you do a write up on how to get the paddle shifters to work or for that matter the whole process? I have a Camaro wheel with paddle shifters and need to plan for the install.
Discussion Starter · #55 ·
http://img.photobucket.com/albums/v244/eddiefromcali/Snapchat-2120725832.jpg[IMG][/QUOTE]
Did you do a write up on how to get the paddle shifters to work or for that matter the whole process? I have a Camaro wheel with paddle shifters and need to plan for the install.[/QUOTE]
Theres a how to for both already. Followed that and i was set.
· Administrator
Discussion Starter · #57 · (Edited)
So you followed both to a T and had no issues?
How to remove and replace your steering wheel
I cannot locate a paddle shifter tutorial
https://www.cruzetalk.com/forum/161...6-how-remove-replace-your-steering-wheel.html
Had to trim my air bag plastic a bit to make it fit on the steering wheel and my bag only had one connector, everything else was just as described in the how tos.
https://www.cruzetalk.com/forum/161...place-your-steering-wheel.html#/topics/137946
Install Working paddle shifters (How-to) https://www.cruzetalk.com/forum/showthread.php?t=137946
· Administrator
I have actually already read that, forgot about it and lost it.
Time to reread and add it to the TOC
Thanks
EDIT:
Now I realize why I could not find it, it was in the wrong subforum
Discussion Starter · #59 · (Edited)
Little audio build update...
Got my Ampere Audio components installed.
Fast rings are awesome, btw
Tweeters in custom pods, slightly on/off axis
Since I tapped into the OEM wiring, I had to make a T-Harness to avoid cutting or splicing into the OEM wiring. I used a PAC LOC, ditched the LOC part and ran 2 different size speed wire bundles to/from my Rockford Fosgate DSR1.
Unmodded PAC unit
From the HU to the DSR1, I used Install Bay 18ga OFC speedwire https://www.amazon.com/gp/product/B004H1KAMQ/ and from the amps to the T-Harness, I used 14ga OFC speedwire I found on ebay. Since I'm running an active setup, I had to run my own wire from the 14ga at the T-Harness to the doors for my tweeters....this is where it got a lil tricky. After soldering all my connections at the harness behind the HU, I ran Knukonceptz wire from there to the front door wiring harness junctions on driver and passenger sides. I didn't want to poke holes or snake wires around the OEM plug, so I bought the required pins for the plug and ran my wiring that way....way way way cleaner than shoving wires through.
Note 39 & 41
Other side, 39 & 41
Started tuning with the DSR1 when I ran into a good deal on a Digital Designs SS5 amp SS5 . So I'm ripping out the Sundowns and going to run a single amp. Did I mention I replaced the Audison mono with a Sundown 1000D and added a 50.4? lol
To throw another wrench at all this, I was given a set of Oncore Audio components to test. https://www.oncore.audio/on6/?p_name=ON SERIES SHOP Which means I gotta rip out all my Ampere stuff and install these. lol
41 - 60 of 91 Posts
