so i installed the valve springs on my motor....simple process, just time consuming. Also went ahead and installed the L and R aero panels with simple self tapping screws. Im waiting on some hardware for the muffler panel and will get that installed asap as well. I wasnt able to secure the pane in a couple of spots because the panel holes were up against the actual floor pan and not a hollow crossmember like most of them were. So the plan is to get some "adhesive or weld mount studs" and stick them on the underside with epoxy to hold up the couple of spots i couldnt drill at. The muffler panel might be trickier since the Verano and Eco use what appears to be a different tank strap that has a stud on it for the panel to fasten to. I might have to just zip tie it or put another weld mount on the heat shield.
Dyno pulls are scheduled for later this week to get baseline numbers before the GTX250 is installed. I am fully prepared to go all out with the new turbo, cant wait.
