Two years ago, I started a thread concerning my 2015 2.0 diesel and how it wouldn't start. It was suggested that I remove the EGR Valve and clean it, as that's a common cause of the engine rough idling at first, then not being able to start, at all. I did as suggested, and everything went perfectly. $15 dollar fix really saved my a$$.
Fast forward to yesterday, and the exact same thing happened, but no sweat, as I figured that's what the issue was.
However, this time around, I was able to remove the bottom torx bolt, but the top torx bolt got stripped, as (apparently) the bit wasn't fully seated when I tried to remove it. (I started this project in low light, right after the sun set, so that's where I messed up)
My question: just how am I supposed to remove that bolt now? The easy(?) answer would appear to just use a bolt/screw extractor, however there simply isn't enough clearance between the engine and the firewall, to get my cordless drill behind it. Would using a Dremel-type tool to cut a slot and then using a large slot screwdriver work?
Suggestions?
(thanks in advance!)
Suggestions?
