So i decided to turn on all 3 EGT sensors while driving. I noticed that EGT #2 seems to fluctuate by 100 to 200 degrees every second. it can be higher than egt 1 and lower than egt 3. and sometimes its right where it needs to be. This leads me to believe that the sensor will soon or eventually throw a code which is probably the most common code mentioned here on the forum. In addition i noticed that the recall has been removed from the chevy owner center.
Logically the egt temps should be highest at 1 then 2 then 3. Hoping it fails before i hit 36k, currently at 28k
