EGT Fluctuating Wildly!
989 Views 5 Replies 3 Participants Last post by  Snipesy
I need some help! My EGT # 2 is fluctuating back and forth from the normal range to between -86 degrees to 2976 degrees. It will hit the top and bottom temps for a microsecond as it is fluctuating. I have replaced both sensor #2 and #3. I have the following codes - P2084, P20E2, P242B. Additionally the fluctuation is much worse with the key in the off position.
The car is running fine but won't pass emissions inspection.
Thanks for any insight on this problem.
Sounds like wiring problem.
The car will struggle to perform a Regen correctly without the EGTs. But beyond that they do not affect engine operation to any noticeable degree.
I am thinking that it could be a wiring harness problem but I think it's kinda weird that it basically goes from short to open like it does
A corroded terminal will have micro arks. high current followed by no current.
If the frequency of this interferes with the ECM ADC. You get a square wave of resistance values. Which is what you are seeing.
The problem is where this ark happens. If it’s in the ECM you are pretty much SOL.
