1 - 2 of 2 Posts
Trying to get my daughters car running properly. It is a 2015 with the 1.4L turbo. It runs smoothly, then sometimes when I start it it runs very rough for about 30 seconds then dies. After I start it again it runs smoothly again. There are an check engine lights or engine codes. A little history prior to this. It used to run real rough then would not start at all. It had a check engine light on and several codes. The codes were 2 O2 sensor codes, a random misfire code, a low boost code. After replacing the battery and the negative battery cable it started to run as it does now and there are no longer any codes. Any idea what the issue could be now.
Thanks for any help.
1 - 2 of 2 Posts
