Ok so about 2 weeks ago, my engine started gurgling randomly while accelerating, the traction control light would come on and check engine light would blink while accelerating, it would randomly do this, lose power at say, 4000 rpm, stay there with low power, it would then "snap on" and shift and work normally, I though it was a trans issue, but it also happens in neutral.
Fair enough, I clean the injectors and throttle body (dirty af) and change the spark plugs (totally coroded) for titanium ones, and the problem disappeared yay!
... For a week, now it's doing the same thing again albeit at a less frequent rate, but it's driving me nuts, I stop in an intersection and when I push the throttle the car will go blurp blurp blurp and the other drivers would yell at me for being in the middle of the road.
I took the car to the dealer around 1 month ago for normal maintenance, and they put more oil than they should if its something... I can't take it back because they charge too much for inspections, mind you a repair.
It's a 1.8 with the 6A, any help or suggestion would be much appreciated.
