First post to forum. Last week my ctd gave me the message that engine was warm enough to self shut down the a.c.. 2 minutes later it started yelling at me to shut the car down. Temp was at the redline. Paid to get it towed to local dealership and paid for diagnostic which revealed absolutely nothing. I'm super upset. They couldn't duplicate the scenario after it got to them. Now I'm $250 short and the issue was not resolved. Any advice ?
1) Always follow the instructions from the car.
2) If you subscribe to the service, you can always push the OnStar button and they will conduct a remote diagnostic.
3) In engine overheat situations you should always turn the heat to max and run the HVAC fan on its highest speed.
4) In your case check for a bad coolant temperature sensor, faulty thermostat, and air trapped in your cooling system. Also check the concentration and ph of your coolant.
What year of Cruze ctd do you have? How many miles? What state or country do you live? Tomko advice was good, shutting car down right away would be a good idea.
The first 3 suggestions were observed but the 4th is getting quite involved for me to handle. And like I said dealer said car seemed fine to them. I dunnoooo
Could be a bad battery as well. This happened on my 2012 Eco, and then a few weeks later, it wouldn't crank. Jumped off a few times, then taken to dealership to find it was a bad battery. Had it replaced there, and never had another issue of the car doing this. However, after falling asleep on the interstate from the famous coolant smell, I dumped this car. And within 2 years, I went thru 4 cars. 12 Cruze Eco -> Sentra -> Elantra -> Cruze -> Elantra Eco
had a gas cruze in our shop 2 weeks ago with intermittent over heating, gauge would go up to red.
finely got it too do it. ended up being cooling fan intermittently would not turn on when commanded. so does yours get hot while steady speed or stop an go?? if it happens again ,get out an see if the fan is on.
Generally, if you're doing more than 30 MPH, the fan isn't an issue. If you're stopped a lot, then the fans are needed.
Discussion Starter · #10 ·
I haven't had battery tested since I've had it. But it cranks and starts every time. The time that happened I remember I idled it for an hour at least. So it may be just an idle issue. Fan is coming on.
Glad you got it fixed.
Fans at highway speeds are probably more common with todays aero and tight engine compartments.
letting these engines idle that long is a no, no.
an it only takes one command cycle when the fan decides not to turn on.
