Previous post on DPF full limp mode. Car back at dealer. Had done 3 regens last week. soot at 77, said they brought back down to 21. Took car down road about 4 miles and got reduced power light again and lot of black smoke. Brought it on home and drained the diesel out and replaced with Exxon diesel. Returned to dealer. They did two more manual regens. Told them to take it out for test drive before I come pick it up. Same thing happened to tech, loaded up, sputtering, and smoking. Said getting all kinds of error codes. They are uncertain where to go next. I had put some Sea Foam in fuel when I thought it was bad fuel. Would this have caused some additional problems? The black smoke coming out exhaust is new concern, may be coincidental. At 158000 miles is it still necessary to only use dexos 5w-30 oil? Seems like oil is getting into exhaust, and I am seeing oily residue around Turbo. Think the Turbo seal may be best place to start looking? After all this soot and re-gens are all the sensors able to get cleared of soot and oil so they work correctly, or do you think I will be looking at replacement of them too?
Sorry for all questions. Not feeling too good about skill level of dealership and I am a long way from any other ones. Think they need all the help I can find.
Definitely want to get that scanguage II, and have sent inquiry in to be sure it is set up from my Cruze diesel
