I just put together a common issues list and posted it.@diesel this looks like something that we need to write a specific thread about and place it as a sticky.
Silly newbie question - but can a diesel backfire?pressure from a backfire with enough force to break the plastic duct.
The duct is hard plastic, not rubber, isn't it? So it probably becomes brittle with the heat-cycling and cracks, perhaps?This has occured with our two highest mileage CTDs. 158,000 and 186,000.
I'm guessing we will all encounter this mechanical failure in due time. In some ways a refreshing change from emissions system faults.
I was wondering this myself.Silly newbie question - but can a diesel backfire?
I would believe that to be very difficult, due to direct injection, and the fact that diesel won't auto-ignite when it's not compressed.I was wondering this myself.
A very good thought.Will see what parts it takes to get Diesel back on the road again, makes me wonder if this is a weak link on higher miles CTD would it make sense to replace this plastic tube/hose if that is what blows out as a precaution maybe when timing belt is replaced? In other words why wait till it fails??? just a thought.
That could be a very good idea, maybe that would hold up longer and just need replaced once and then just inspect it at each oil change? I wonder if one was looking it prior to failure if it is showing signs of failure like a crack or something?? maybe not.A very good thought.
There's also a guy who makes custom Kevlar-lined silicone hoses for the aircraft industry. He's currently produced some for duramax. I'm wondering if he'd make a replacement for us.
CSOBeech - Gee Bee Beechcraft Product Store
Diesel said he heard a pop noise so instantly I though backfire but more I think about it I can`t come up with away it would especially with direct injection an compression ignition...................thanks forSilly newbie question - but can a diesel backfire?
Definitely follow your logic. Could that pop sound have been the duct coming off?Diesel said he heard a pop noise so instantly I though backfire but more I think about it I can`t come up with away it would especially with direct injection an compression ignition...................thanks for
making me think. that intake is bolted an clamped an doesn`t move, so why would it blow off an break ??, or it appears like it blew off.
That was my thought, but then I realized that other then very wrong ignition timing, I didn't know why a gas engine backfires.I would believe that to be very difficult, due to direct injection, and the fact that diesel won't auto-ignite when it's not compressed.
I`m convinced there had to be a positive pressure to make that duct separate from the throttle assembly. a none turbo or none supercharged gas or diesel engine would never do that .Definitely follow your logic. Could that pop sound have been the duct coming off?
Plastic snapping in shear would make a lot of noise.Definitely follow your logic. Could that pop sound have been the duct coming off?
the piece that broke is bolted to the top of the engine so unless the bolt came loose an fell out can`t see how its going to move.Since this is a intercooler hose, isn't this connecting something bolted to the frame with something bolted to the engine? Since engines do move on the motor mounts under load, there'd would have to be some flex somewhere.
Which raises another question - what happens when the motor mounts start going bad? Because it could cause excess engine movement. This might be the weak link when that starts to happen.
Yes, it should only be compressed air from the turbo. That's a good point - you should not have had either...I am a bit confused though. When this happened, I had smoke and strong diesel fumes, but doesn't an intercooler cool the clean intake air?
