cant see why it would be beyond our reach,Fellas,
Does anyone know if this can be replaced at home or does it require special tools? I haven't seen anyone else post about this other than this thread here.
So question, last night I was driving my car around town and it went into reduced power mode, I noticed the engine compartment was smoking a little bit which I'm not entirely sure why and it's been making this kind of whistlening sound, my brother in law says it sounds kind of like turbo bearings going bad. And so I was looking around the engine compartment in the dark and that intercooler tube appears to be loose but I'm not entirely sure, I can slide it back and forth maybe like 3/16" of an inch and I tested it, I pushed it all the way in and then revved the car to about 3k rpm's and checked it again and it had pushed it out the 3/16" of an inch or so. I don't know if this is the cause of the reduced power mode, maybe the whistle sound if air is leaking into it, and the reduced power mode? A couple days ago, a message popped up saying DPF filter full keep driving, I kept driving probably 30-miles after the message went away at highway speeds it seemed to work fine. The other day though, the only 'bad' thing I did was idle it for maybe 2 hours in the parking lot while talking on the phone, so not sure if maybe that clogged up the DPF filter or not.So, just the pipe and all is well. i am not sure why they listed that gasket - it's the wrong gasket as far as i can tell, but I am not 100% sure. I am also not sure why the OP needed all the extra stuff. Probably driving it for 20 miles like that caused damage. My soot grams were exactly where they were when the issue happened, and no other components were broken.
