1 - 4 of 4 Posts
I need some GM Technician help. I am preparing the car for track days on a road race course and looking into adding a little bigger oil cooler with a thermostat. I have looked at pictures of the oil cooler assembly that is on the car, which I have attached to the post, but I can't figure out how it actually works. If anyone can explain all the channels, the 4 holes in the cooler, and if it has a thermostat, I would be happy to do that over the phone. Aside from fabricating a new plate, does anyone know of a way to tap into the system to add an external cooler?
Auto part
Auto part Exhaust manifold Automotive super charger part Automotive engine part Automotive air manifold
Auto part Metal
No thermostat. Operation is very simple...oil flows into one area of the cooler, and engine coolant flows into the other (2 holes for oil, 2 for coolant). The coolant helps warm the oil up form a cold startup, and also helps cool it once at operating temperature. I wouldn't go replacing it, unless you have verified that engine oil temps are routinely over 275*...and you can't use a scan tool to check. The Cruze uses a "calculated" engine oil temp. You'll have to use a temp probe in the oil pan, to get real numbers.
Reactions: spacedout
Thanks for explaining Brad. It makes sense now. I had no idea coolant ran through it, and couldn't see the lines. My head was spinning trying to figure out from a picture what the other two holes were for.
1 - 4 of 4 Posts
