have you upgraded the headlight bulbs in the meantime?
There are these on ebay that I have been considering for my 2015...
2015 2016 Chevy Cruze Fog Lights Clear Lamp Bulbs Wiring Harness Switch Kit | eBay
And these that are a similar...
2015 2016 Chevy Cruze Driving Bumper Fog Lights Lamps Switch Complete Left Right | eBay
I figured if I do go that route I would also install the factory optional fog light switch and wire a relay to trigger the new lights from the factory switch so that I do not have to install a clunky extra switch somewhere to turn on the foglights. The switches are on ebay too...
Headlight Switch ACDelco GM Original Equipment 22901646 | eBay
how would you wire it up?I figured if I do go that route I would also install the factory optional fog light switch and wire a relay to trigger the new lights from the factory switch so that I do not have to install a clunky extra switch somewhere to turn on the foglights. The switches are on ebay too...
Replace the switch with the current non-fog switch and add a wire to the harness if needed for the fog output to trigger a relay. But the car may be harnesses and wired for the fog circuit already...how would you wire it up?
I figured as much, but haven't looked into it at all yet...There's been a number of threads about adding fogs to non-diesel cruzes. I'd think it would work the same for you. IIRC, a number of them just changed the switch. Some needed to have a dealer re-program. Apparently, it's not hard to do it "factory" without auxiliary wiring.
i hope the cruze did like my old zj did. had the wire harness for the fogs but if you didn't have that option it was a hanging plug and went into the control panel inside just plug in factory fogs and boom they work
No, the harness is not there if you don't have fogs. I installed the factory gm fog light kit in mine and it comes with the fogs, the new switch, and the fog light harness that you have to install and run to the fuse box. Some vehicles also have to be flashed by the dealer to enable the fog lights, but some don't. Mine didn't.i hope the cruze did like my old zj did. had the wire harness for the fogs but if you didn't have that option it was a hanging plug and went into the control panel inside just plug in factory fogs and boom they work
Has anyone had had the front facia off their car to know if there is a fog light wire harness present or not?
I have a friend who is who is a GM body mechanic. If someone doesn't chime in on this I'll ask him next week. I'd really like to add those fog lights to my car and the GM factory switch. Hope like **** its plug and play.
