From my car:
Front Passenger window
Rear Passenger window
Now that I look at them , it seams as if my windows are all the same. Doesn't look like it from where I'm standing though. I'll have to take a few more pics of the other glass after it stops raining to see.
Edit:
Found that
DOT 747 means that the manufacturer is FUYAO GROUP SHANGHAI CO., LTD. SHANGHAI CHINA (
I used this website)
The
M540 is a model number for the piece of glass, which identifies the type of construction. The M number is unique to the manufacturer, so one an M number of M312 by one manufacturer could be different than glass labeled as M312 by another manufacturer. It identifies the glass construction, including the color and thickness. An M number may be used by multiple part numbers.
The AS in
AS2 stands for American Standard, followed by a number indicating the position in which the glass may be used, based on its optical quality. AS1 is the clearest glass (at least 70% light transmission), is laminated, and can be used anywhere in a motor vehicle (typically just the windshield),
AS2 is tempered with at least 70% light transmissions, and can be used anywhere except the windshield, and AS3 can be used in certain locations in certain vehicles (and can be laminated or tempered, and has less than 70% light transmission). There are higher numbers used for other purposes, but are not normally encountered in cars. This number must be near the manufacturer’s name/logo, preferably below it (per Z26.1996).
The
43R number implies Conformity with the European standard of safety ECE R43.
The
E4 in a circle means that the Netherlands approved it for use in their country and because there is no roman Numerals above this code it further signifies that it is a Non-windshield with tinting less than 70%
The
CCC and the
E000199 number means Conformity with the Chinese standard of safety CCC E000199/E000039.
The
.3 decodes as follows: Number, month and year of manufacturing: the figure with points designates year, the sum of points to figure – month of manufacturing, the sum of points after figure – month of manufacturing + 6.
I am guessing based on this that the front was manufactured in Jan 2013 and the rear in Feb 2013.
